Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Screen showing "safeguard" ??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Screen showing "safeguard" ??
    Found threads on here and elsewhere. All leading to fuses relating to alarm, siren etc. I've checked and alarm is fine! All fuses are fine I removed and checked each fuse!
    I also get washer fluid level even it's full but still comes up!
    What else does safeguard relate to? Radio works great, everything's fine so far! Stumped !!!
    Regular Member John Bishop's Avatar
    Oct 2010
    As you have the estate it could be the rear side windows
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    my car had same prob and needed new alarm wiring loom above head lining
    11 Post(s)
    Quote Originally Posted by Humourbash View Post
    I've checked and alarm is fine! !
    It can't be, else the safeguard message wouldn't appear.
    Need the fault code(s) reading out. Guesswork isn't always a reliable method of fixing something.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Posting all of your info would maybe help here
    Have you by any chance just fitted this?
    http://www.vectra-c.com/forum/showth...d30-and-screen
    If so then the the screen must have check control enabled but your car won't have the washer bottle sensor
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by John IS3 View Post
    just replied to that lol. washer bottle sensor, is this something i can add or PM me instructions how to disable this via the software we arent allowed to mention.
    i will check this sensor thing that are attached to the mapreading internal light as it came with the unit when i bought it after i bought the car. i still have the one came from this car. so i will access this area tomorrow and see if i can fix it. as i had the leak from the hole made by the previous owner who had a CV or something inserted for a loom on the roof above the light. it was leaking so i sealant it up and no more leaks now. maybe the leak into the wiring caused a problem? as this error did not appear before i went to fix the leak. [please agree with me????] lol
    Oct 2010
    Check the rear window sensors on both sides. I had same problem, there are How2's on here to bypass it. Common fault with estates
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    one. i never touched the alarm thing in the boot, i know its not affected. even the horn.
    two. all fuses been checked and matches the recommended amps for that area. even filled the empty ones that have the clip in thing. i filled them. and some fuses was in the wrong amp size so corrected them (Hoped this would solve the battery light issue but sadly no. its a new altnerator that causing this to come up!!!)
    three. all alarms are fine, i will check the internal light alarm bit.
    I tested the alarm. it works perfectly. even my boy in the car. i set the alarm on and it went off. confused!!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by bishbang View Post
    what is this? rear windows as in boot windows on the sides with alarm sensor on each window??
    fuses been checked. fine. i dont wanna bypass this alarm bit as i do have tools in the day in the car boot and i empty it out when not using the tools.
    Oct 2010
    You dont have to touch the alarm system for it to bring the check safeguard up. The sensors on the windows corrode and crack causing the message on the screen but the alarm still works.
  1. Anyone know what a "SAFEGUARD" warning in info display means?
    By andy d in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2016, 21:00
  2. "Check Safeguard"
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 13:59
  3. "Check Safeguard" on Display
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 21:07
  4. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
  5. "Safeguard Check??"
    By MikeO in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2009, 18:11
