Thread: help... :(
    Regular Member farmboy91's Avatar
    Aug 2011
    ipswich
    confused help... :(
    jus recenty had new rear discs n pads fitted and they have bin fine up until a week ago.... first i noticed the speedo drop then rise back to the speed i was actually traveling at closely followed by the abs n traction control lights appearing from cold the is movement in the brake peddle i dont know where to start the speedo made me think along the lines of a sensor gearbox wise any1 else had this sorta problem?
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try wd 40 abs plug first
    Aug 2011
    ipswich
    ok cheers
    wirral
    58 Post(s)
    Trim : Basic
    Engine : 1.9
    What do you mean by movement in brake pedal?
    Aug 2011
    ipswich
    viberation before the brakes engage if you know what i mean? the bloke who change them over said said to keep an eye on them cause the caliper on one of the brakes to a fair bit of effort to wind back
    Aug 2011
    ipswich
    you can hear it aswell same sorta noise as if you brake in ice n the wheel try to lock
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    My guess would be the one that was 'hard to wind back' is seized or close to seizing. The effect will be a speed mismatch between wheels which the braking system will interpret as skidding and thus the ABS is kicking in.
    I'd be looking at overhauling the calipers or if necessary replacing at least the 'dodgy' one.
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    could be wheelbearing if it has magnetic pick up , or speed sensor on the wheel
    Aug 2011
    ipswich
    ok cheers all gna whip them off weds n have a look
