Thread: fault code p2452-0f
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default fault code p2452-0f
    anyone know what this code means please?
    i also have p2279 but that seems to mean intake or egr valve.
    1.9cdti 150 if that helps
    Regular Member shaunft's Avatar
    May 2012
    mansfield
    p2452 code / deisel particulate filter differential pressure sensor circuit
    p 2279 intake air system leak
    Sep 2011
    Birmingham
    Trim : sri
    Quote Originally Posted by shaunft View Post
    oic, thank you.
    i did wonder if it was stuck in a regen cycle, seems the dpf might be at fault then.
    is the oxygen sensor easy to get at or would it be easier all round to take the dpf off and smash the insides out to make the car drivable?
    May 2012
    mansfield
    hi i have a program called vauxhall_2010_wsm-vmware player within this is TIS 2000 which shows every procedure and make and model of vauxhall from servicing to how 2 everything you would need for fault finding to repairing your car with diagrams i bought this of emanule for £10 worth every penny
    anyway your o2 sensor seems to be around the altonator area of your car as is the wireing harness for o2 sensor
    Sep 2011
    Birmingham
    Trim : sri
    excellent, thank you
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. fault code
    By mvl41183 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 10:00
  3. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
p2452-0f
p2452 opel vectra
Opel P2452
p2452 vauxhall
Vauxhall P2452
vectra c fault code p2452-0f
p2452 fault code
zafira p2279 & p2452 code
p2452-0f opel
vectra c 1.9 cdti p2452
p2452 vauxhall vectra
p2452-0f vauxhall
2009 1.9cdti zafira p2452 code
vauxhall fault code p2452
Vauxhall DTC P2452-0F
p2452 opel
