Results 1 to 2 of 2
Thread: When replacing shocks and springs....
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default When replacing shocks and springs....
    Is there anything else worth replacing/upgrading at the same time?
    The car is an '04 SRi 2.0T
    SAAB uprated droplinks seem to be a worthwhile upgrade but I've also read somewhere about replacing top mounts/bearings?
    kev , you only need to replace top mounts if one of the threads is ruined in it as its only a locating plate for the suspension to join the inner wing
    when you dis assemble the strut into parts just get the top bearing ( its round and black and locatres on the top of the spring ) and move it around turning the top part against the bottom bit ( youll understand )
    if theres any grating or its hard to move , replace them but it they move nice and smooth and freely then the choice is yours
    you can change the drop links as you have to remove the top of the droplink from the strut when you remove it so if there not new and slightly worn its the perfect time to do them as it only means undoing the nut that holds it onto the anti roll bar
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. Replacing new front shocks. What else?
    By Marky in forum Handling & Braking
    Last Post: 20th August 2012, 15:14
  3. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  4. Replacing rear signum springs
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 11:49
  5. Replacing rear shocks
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2008, 17:47
