Thread: weird noise in engine bay. 1.9cdti 120ps 2005
    May 2012
    St ives
    Default weird noise in engine bay. 1.9cdti 120ps 2005
    Ok so apart from the struggling to start problems which i am looking into:-
    Glow plugs, Leak off pipes, Injector seals, battery, starter motor.
    I can here a loud noise coming from the drivers side of the engine bay, sounds as if its underneath where the air box is, sounds almost like a metal scraping on metal sound.
    Can anyone please recommend what this may be and how i go about fixing it.
    Many thanks
    Alex
    PRESTON
    Check the crank pulley. These are a vibration damper with a rubber core, they split and the outer ring seperates from the inner.
    Jun 2012
    Birmingham
    Mine used to struggle get your battery checked first before you do anything else, and as above it will be a pulley that's making the noise shouldn't be to costly if replaced sooner rather than later
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    hi m8 theres a thread on here about the difficult to start bit n the op sorted it with a new starter motor its in engine and drivetrain section hth
    gaz
    May 2012
    St ives
    Thanks for the replies. I've been looking through the service book and I don't think the belt has ever been changed. 7 years/108,000 miles. Are the belt kits with pulleys on eBay any good?
  1. Weird Engine Noise after Service 2.2 Petrol '04
    By solamanda in forum Engine & Drivetrain
    Last Post: 22nd August 2012, 20:04
  2. weird noise 1.9cdti
    By tomo610 in forum Engine & Drivetrain
    Last Post: 19th February 2012, 17:07
  3. Weird engine problem on a 1.9cdti 150!!
    By new2theroad in forum Engine & Drivetrain
    Last Post: 2nd July 2011, 23:48
  4. Irritating Whirring Noise... grrr 1.9cdti (120ps)
    By Meady in forum Engine & Drivetrain
    Last Post: 6th April 2011, 07:30
