Thread: suspension knocking again
    wirral
    Default suspension knocking again
    my suspension seems to be knocking again i have changed my n/s fromt spring and i refitted the rubbers top and btm of the spring and a local garage changed my o/s front spring and didnt fit the rubbers back to the spring that side could that be the knock?? if so anyone know the part number and ill change myself ?
    ive also changed the front drop links twice so could even be those and other ideas its not doing it all the time it can be great for 15-20 mins then might knock twice and be ok again for a while just annoying not knowing what it is??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    How old are the drop links where they cheap ones?
    Drop links would be my favourite unless one of springs isn't say correctly?
    Whats mileage on the car?
    Things to check.
    Springs
    drop links
    arb an bushes
    top mounts
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    I was getting a knock on mine changed arb bushes and its fine just need to change rad mounts,.
    Regular Member Keif's Avatar
    In the Garage
    Soon as I read the title, first thought. Front Anti Roll Bar bushes. Treat your car to Some Powerflex ones.
    wirral
    thanks for all your replies in reply to critch my car is 55 plate with 70k yes they were both cheap sets of drop links off fleabay last changed about 3 mths ago
    how easy are the arb bushes to change and where can i get powerflex bushes?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    In my experience cheap drop links don't stand upto the job mine only lasted a few months.
    Arb bushes are fairly easy to change.
    Not sure about powerflex ones as I just used new ones from dealer only 3 quid each
    wirral
    just having a quick look seems to be 24mm or 25mm arb bushes is there a way of knowing which it will be without taking apart the car is cdti 150bhp 55 plate i see your local to me critch u get your parts from lookers?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Sometimes you can see the part number on rubber.
    Yes lookers Birkenhead Stan the parts guy is always really helpfull.
    In the Garage
    www.powerflexshop.com cheapest place i've found.
  1. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  2. Knocking suspension
    By cosjon in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 14:55
  3. knocking on o/s suspension
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 15:18
  4. Knocking suspension
    By marko21 in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2008, 15:24
  5. Suspension Knocking
    By D-S-Dave in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2007, 01:31
