Results 1 to 10 of 17
Thread: After MAS Remap
    Regular Member amand's Avatar
    Feb 2011
    west London
    Default After MAS Remap
    My economy is not soo good. i get like 350 to a tank on a 1.9 16v. thats all mixed driving and some booting. however even when booting it i dont seem to get the response everyone else is getting. ie 5th gear 30mph and I press the throttle more and it lags just like before. i mean its faster but it does smoke when i boot it initially.will the economy be bad when driving with air con on? im getting like 30mpg or so. any thoughts? egr also deleted. major servicing was done too in september
    How's your inlet manifold and swirl bar looking...?
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Thats wierd, ive got the same map and i get atleast 50 mpg average normaly. On a motorway run cruising at 75ish i get 57mpg. 30mpg is not right, lowest my average mpg has read is 45! I dont think air con affects it that much mate
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Ive got the same map and my lowest MPG is 42mpg over the last 1000 miles. I dont do huge amounts of motorway but when i do, i can get it to about 52mpg.
    As above, whats the state of your inlet? (mine was shot when i had the map done, Now its a new inlet it made a noticeable difference.
    Feb 2011
    west London
    well there is oil deposits around each swirl and the injector rail has dark deposits around it at each point also. if i boot it i can see the fuel needle going towards empty.
    Feb 2011
    west London
    you dont reckon it would be the throttle body do you? also since i delted egr valve can i remove the actual part? because its like a flat spot when criusing 30 in 5th and need to speed up.
    Did you blank the egr valve when it was mapped out? The valve can't be physically removed as the ecu still knows its meant to. Be there, it just doesn't do anything with it. If you take the plug off and run the engine it will put the emmissions light on after a while...
    Any other lights or fault codes coming up.
    Feb 2011
    west London
    nope just light bulb. other than that its all good. the problem was my car wasnt mapped custom it was a mapped already made of 190bhp as claimed. but reading from everyone it seems a good map. i mean it is faster than before but im just not impressed with 400 out of a tank. how much would you get?
    Was it blanked off too mate? You have another issue somewhere as mine has the same map from Ben and makes 700 to a tank without any problems...
    Feb 2011
    west London
    no blank, would fuel filter affect it? tracking? 400 to a tank is appauling for a diesel even if it is town driving. ive had thermostat changed so its not that. ive cleaned boost sensor.
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. 2.0t remap from remap science bradford
    By stefan7153 in forum Petrol Engine related
    Last Post: 4th May 2011, 22:03
  3. 2.2 dti remap
    By fattony in forum Diesel Engine related
    Last Post: 11th December 2008, 10:41
  4. 2.2 Remap
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2008, 17:48
