Results 1 to 10 of 14
Thread: GSi/SRi Owners.
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default GSi/SRi Owners.
    Could someone please measure the distance between the top of the front wheel and the wheel arch directly above,
    Had car MOT'd today and had to replace both front struts and front coil springs, but I think Euro Car Parts have supplied standard springs not for GSi, the car is sitting too high at the front now.
    Have checked on their website and the springs are the same whether GSi or if Vectra 1.8. Not happy if they have screwed up.
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Measured mine
    1. From top of tyre to wheel arch is approx 4"
    2. From centre of wheeel to wheel arch is approx 16"
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Havent checked mine as i am lowered and have 18" wheels but that sounds deffo like you have the wrong springs.
    When i needed a front spring for my gsi, i couldnt get any from motor factors, they only did 1 size for vectras. The only place i could find was vauxhall at £185 + vat for a pair (2year ago). In end i got full set of -30mm PI springs off ebay as it was cheaper than a pair of stock ones!
    4" is a huge gap imo, although springs will settle, i doubt theyll settle that much
    May 2012
    chelmsford
    hi mate. its 2.5 inches 52 plate gsi 153,500 miles on the clock
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    You also need to make sure your you get the correct rating of spring for your vehicle axle weights. These can be found on the drivers door pillar. A set of uprated / lowered springs usually works to be the best route......
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    I have started a thread compiling this type of data regarding different spring shock set ups. I think it would be a useful tool for people to use as a reference point as to see what sort of drop/setup they want before spending their hard earned. Take a look. The more input data collected the better.
    http://www.vectra-c.com/forum/showth...e-Running-With
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I've just measured mine as it's on it's original running gear:
    54 plate preface GSi - 50k miles
    17inch GSi alloys
    215/50 R 17 tyres
    Front:
    Distance top of tread to arch - 2in
    Distance centre of hub to arch - 15in
    Rear:
    Distance top of treat to arch - 1.5in
    Distance centre of hub to arch - 14in
    Hope that helps.
    Regular Member John Bishop's Avatar
    Oct 2010
    55 plate SRi 3.0 v6, standard 17 inch alloys with original spec springs and shocks. 2.5 inches from top of tyre to arch on the front
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Thanks Andy and Bish. I thought it looked too high. I am running 225's all round but shouldn't make that much difference in the distance
    Will ring Euro on Wednesday. Question now is where to get springs from. The only reason i bought from them
    was cos it was desperate and the only place that had stock.
    Oct 2010
    Know how you feel Tango. Am after a LUK clutch kit for mine and there are none in the UK. Even LUK don't have any!
  1. All 2.8T owners....
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 21:15
  2. Hello to all VX Owners
    By MattVecVXR in forum Introduce yourself.
    Last Post: 16th March 2012, 11:48
  3. Vec 2.2 dti sri owners
    By SUBEK in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2011, 12:39
  4. 2.0t owners wot mpg u get
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2011, 19:24
  5. !!!Attention all diesel owners!!! (Petrol owners may want a look too!)
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2009, 20:56
vxr vectra distance between wheel and wheel arch
