Results 1 to 10 of 13
Thread: 1.9 diesel vectra not starting
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    Default 1.9 diesel vectra not starting
    2006 diesel vectra won't start Will not crank over has no eml light on dash no fuel pump running Tried a Bosch code reader engine ECU not showing believe it could be no power to the ECU anyone had such a problem and how did you cure it By the way all fuses seem fine and all the contacts on the bottom of the fusebox appear good
    Engine : 1.9 CDTi
    Flat battery?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Apparently there is a plug at the power steering pump and it could be loose, rendering the car immobile iirc. Could also be a frayed cable/wiring harness.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by vectrahunter View Post
    1. Check wiring to ECU
    2. Check earthing points
    3. Remove ECU for testing/repair located in drivers wing front in a cradle can be stiff to remove.
    BTW number 3 is the most common fault.
    @ £120 to get them repaired
    Feb 2007
    crosshouse
    Thanks for replying
    Is the ECU behind the splash guard ? Do u know of anybody in the Glasgow area that can do repairs
    Feb 2007
    crosshouse
    Had the Ecu tested no fault found car still won't start checked all relays wiring and connections all seem fine battery charged and no blown fuses any ideas welcome
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    have you done a total vehicle read out with diagnostics such as opcom ?
    there could be a problem somewhere on the can network that may well show up in one of the other ECU's
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Have you tried looking at the connection on the power steering pump as Gaz said? Simmo3187's car was in the garage after a clutch and flywheel change, they couldn't get the car to start after it being there for 2 days. Went up there, plugged the diagnostics in, no communication to power steering pump as well as engine ECU. Quick look down the back of the engine reveled the plug wasn't connected. Plugged it in and off it went.
    Feb 2007
    crosshouse
    cars finally repaired turned out to be a canbus fault wiring now repaired happy days
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    good to hear its sorted john and good to see u back on the forum mate
  1. Vectra estate 3.0 V6 SRi, diesel. 2007. Cutting out/not starting! ...
    By Katie in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2013, 16:49
  2. starting a 1.9 diesel
    By tyler boy in forum Engine & Drivetrain
    Last Post: 2nd April 2011, 23:41
  3. Starting a diesel car...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 18:18
  4. Diesel cold starting??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 14:32
  5. Diesel 2.2 SRi Not starting
    By Jv6CDX in forum Engine & Drivetrain
    Last Post: 21st February 2009, 00:11
vectra 2005 changed clutch wont start no communication with ecu
2005 vectra no communication with ecu
vectra c not starting after two days
