Thread: Is there an ignition live in the boot ?
    Regular Member muffking's Avatar
    Default Is there an ignition live in the boot ?
    After doing a search for ignition supply I have found that there are a couple of ways to get an ignition live from the front i.e. the cigarette lighter supply or headlight switch supply, I even found a permanent supply for my RoadAngel Classic from my heater fan behind the glovebox, but in order for me to fit my SatNav unit in the boot I could really do with an ignition live near the rear fuse box if anyone knows the best way as it would save me running a power cable along the sill.
    [Ex]Admin Duncan's Avatar
    GreenGrowler has got both ignition and permanent live from there (in his estate) using some sort of switch - so I'm sure he'll be able to help.
    I keep meaning to source a permanent live from the rear box in my Signum so that I can fit a 12V socket to power cool boxes etc.
    Jul 2006
    In the estate there's a 12v accessory socket supplied in the boot space - don't know about the hatch/saloon. Sorry!
    Well I've just been out again and moved my RoadAngel supply to the front cigarette lighter socket and ran a lead with a bullet socket from the switched 12v to behind the glovebox just in case I need to run it to the boot when I start fitting the Navi unit.
    For now though I've taken out my old headunit and am hoping to be able to fit my DIN screen before I get the facia adaptor, but I'm currently trying to wire in my Autoleads Telemute adaptor between the ISO/CANBUS lead. So far I've got the new headunit all working ok, but am going back out again to see if I can get the phone kit to mute the stereo now I've found out via the NET what the mute wire on my Nokia car kit is (yellow).
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. ignition live
    By Nessy in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 19:23
  3. Ignition Live in the boot
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 14:58
  4. ignition live
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2011, 23:45
  5. ignition live
    By kenny22 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 22:35
where is there an ignition live in rear of vectra c
