Thread: possible alternater failing?
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    So the past two times I've startedy car my radio has gone quiet. This is only when starting the car. I have to turn the radio off and on again but works fine after.
    Charge is fine from it to the battery.
    Battery seems to hold charge however i think itbis due car is 06 plate and its on the original battery still.
    Is this sign of alternate failing or nothing to worry about?
    Or even my battery?
    Excuse the spelling. Cant use this phone at all lol
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    does the car start all of the time?
    May 2012
    chelmsford
    maybe a diode going in the alternator
    Feb 2012
    Sheffield
    Quote Originally Posted by vectra ste View Post
    Starts perfect every single time, There are no other faults the i can see, Its purley the radio/CD, The BC, Sat nav all works fines, It just the Radio the screen stays on and shows hallam FM but no sound unless i turn off and back on.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Put your head unit into "test mode" and keep an eye on the voltage when you're driving. Should be between 14 and 15 volts when driving with no electrics (lights, etc) turned on
    Feb 2012
    Sheffield
    I've tried many times with the test mode but never see anything extra.
    Feb 2012
    Sheffield
    Ok, i was been stupid, This morning i got it into the test mode!
    When running (i did a 10 mile drive) it sat at 14.1v - 14.3v.
    a few more thing that may help -
    - Car starts perfect every time.
    - Ive turned my Auto head lights off, as no matter what, they think its dark.
    - When starting the head unit sometimes stop playing sound, Everything will stay on but from speakers can only here a clicking sound every few seconds.
    - Turn HU off and on, works perfect.
    - Everything else works perfectly fine on HU without restarting it, This is only the Radio.
    - Battery Holds charge no problem, and multimeter confirms the 14.1v when running.
    - My phone screen when left plugged in and i start the car stops charging, until i unplug/re plug it - Phone screen stats voltage too high - This is one i found this morning, it only happened on one start though, (i stopped/started the engine several times) So could be a 1 off/cheap USB Charger.
    I will update with more info as/when i get it.
    I am slightly concerned for my battery, It an 06 plate car, and on the Original battery, Should I be looking to replace this asap? (Isn't it every 5 years)
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I think the only way to find out is to replace the battery, and also, IMHO, fit the biggest capacity one you can fit in the box.
    Feb 2012
    Sheffield
    Just fitted a new battery, For some odd reason i think it had the wrong battery in, 1.9cdti with a 63ah battery! So now fitted the correct one.
    Bosch S5 74ah £61.99.
    My Test mode when driving around sits at 14.1v - 14.2v and when ignotion is off it obviously drops. Is this correct or am i right in thinking it should be around the 14.4v - 14.5v?
    May 2012
    chelmsford
    About 14.3 when running mate. A cold battery which means bonnet latch open, but no bonnet left upfor a day thn put meter on it you want to see 12.6 if above then all is good
  1. alternater fault
    By mash in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2012, 14:27
  2. Battery Failing Maybe
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 17:03
  3. Possible Oil Pump failing???
    By dtmwelburn in forum Engine & Drivetrain
    Last Post: 11th September 2011, 19:52
  4. smoking alternater
    By jofenan in forum Engine & Drivetrain
    Last Post: 28th January 2011, 08:47
  5. cdr2005 failing
    By tarandy in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2006, 20:13
