Thread: Air con issues - Vauxhall cant help, can you?
    London
    Default Air con issues - Vauxhall cant help, can you?
    Hi guys,
    bought a 07 plate Vectra last year and have issues with the AC.
    Basically as it got warmer last year the aircon didnt work.
    So went to VX dealer who looked at it and stated that the condenser needs replacing.
    Paid £600+ for that and after 3-4 weeks it went warmer and warmer again. So back to VX who looked at it and said that they cant find any other leaks. They refilled it free of charge.
    3 weeks aftert that AC just started to blow warm again
    So VX had the car for another 2 days - no result
    So they quoted that it could be the evapourator which is located behind the dashboard. This would cost around £900, mainly for the labour the get the dash off, though they cant garantee that this would be the issue
    So I left it as winter was approaching.
    Went to a different Vx dealer last week who looked at it and couldnt find any leak either. Refilled it with dye and asked me to come back in a week.
    On collection I mentioned to him about the evap (didnt want to say it before, to see what they come up with) and to my surprise, he said that there are no AC parts behind the dash apart from the 2 pipes that direct the cold air into the cockpit.
    So, can someone of you experts put some light on this?
    Apparently all AC part are in the engine compartment and if there was to be a leak, then it would be there. But since they cant see dye anywhere .....
    So my own logical theory would be that there might be a leak within the compressor? Maybe on the inside somewhere to release the gas into the cockpit without actually showing any signs on the outside of the part itself?
    Please someone must be able to put some lights on my mysery
    Thanks folks
    Admin plasma's Avatar
    On the Forum
    314 Post(s)
    Engine : 150
    Mileage : 74000
    Hi mate.
    There is indeed an evaporator inside the cabin. If this is leaking then I believe you would smell and choke on it. It needs the dye adding to it and tracing properly
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    West
    Only way to tell is get the uv light out & look for the leaked dye
    London
    Both VX dealer used the UV lights to track the leak.
    I also mentioned to them to check the cabin air vents for any dye with the UV in case it is the vaporator as this will blow the dye into the cabin.
    I dont know how the AC gas smells. Would it be that bad that you are choking on it? then thats not the case.
    A
    Sep 2010
    same for me too i'm afraid,.. 2 year saga now for me with VX ... useless winkers....
    London
    Quote Originally Posted by chewy71 View Post
    Oh no. So you are having the same issue?
    You would think that VX would find an issue like that with all the high tec they use ;o(
    I guess open window it is and sweaty shirts then if you have the same unidentifiable issue
    Sep 2010
    It has been in 5 times for this fault to the point of the dealer ignoring my attempts to book in.. Had to get VX involved and they have asked to have the car booked in to monitor it. point being it was first submitted under manufacturers warranty... Both my Vecs (have 2) have the same problem... inface I've had three Vectra Cs ALL with this problem!!
    London
    I am really shocked to hear that?
    So it appears no point pursuing this any further as Vx seems incapable ofrectifying this fault ;o(
    South east
    Might be worth taking the car to an air conditioning specialist, rather than a garage that also does air con regases and services.
    London
    mhm .... that might be an option,.
    Though I thought .. IF someone can fix it ... then VX as they might have most experience with their own cars
    But maybe I should think outside the box here .....
  1. The vauxhall is dead, long live the Vauxhall!
    By Matt8 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2011, 16:42
  2. Issues on getting a new key
    By dragonuk2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2010, 15:44
  3. Performance Vauxhall Shootout @ Crail Raceway with Total Vauxhall Magazine
    By Vauxhall_Shootout in forum West Scotland RO - Mr Gee, ARO - RBH
    Last Post: 14th October 2008, 23:42
  4. Replies: 10
    Last Post: 19th May 2008, 23:32
  5. Vauxhall owner who turned to SAAB, now back to Vauxhall
    By scotty_11 in forum Introduce yourself.
    Last Post: 22nd May 2007, 16:32
