Results 1 to 10 of 19
Thread: Calling 2.0 DTI Owners, preferably 2.0 DTI Design.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Calling 2.0 DTI Owners, preferably 2.0 DTI Design.
    Guys,
    Im going to (hopefully) look at a car tomorrow, its a 2.0 DTI Design on a 2005/05-reg, I take it its the very LAST of the 2.0 DTI's?
    Anyway, what are they like? Engine, performance, economy, general drive?
    Is it powerful enough for the body?
    Also, whats the Design like, I know they come with the DAB and all the usual toys an LS has but is it generally a decent model?
    Its a Pre-Face also, as the 05-reg probably suggests !
    Thanks.
    Sodding Typical on Sea
    I have driven plenty of 2.0 DTi's and always found them on a par with the old 1.8 for performance but need to be worked really hard to make rapid progress, I also find because they need worked hard economy isn't brilliant.
    Birmingham
    My outgoing Vec-B is a 2.0 DTI too and I also found that needed a lot of work to get it to the desired speed.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    What mileage is the car?
    I have had a couple of Dti's and i liked them, and when they are working they are good, but they can have some problems mostly to do with the turbo and boost pipes.
    I used to get just under 50mpg, and I found them fast enough.
    The cat converter gets carboned up and needs bashing out, a freeflow air filter helps too, and 2 stroke oil added to the fuel tank will help to lubricate the fuel pump.
    But No Dual Mass Flywheel or Diesel Particulate Filter to go wrong. Yea!!
    Birmingham
    Its got bang on 100k. Has had a new clutch in it, same owner for 6 years and only 1 previous. Says it comes with FSH too. Ive checked MOT's they all correspond to miles, etc.
    Regular Member nwmlarge's Avatar
    May 2012
    United Kingdom
    Quote Originally Posted by TonyP2020 View Post
    are you sure ? i'm pretty sure they do have one.
    My DTI seems ok on fuel getting about 45-50 with a mix of city and rural driving.
    not as fast as my bora 115pd though.
    West
    The dti deffo does have DMF, although due to the lack of torque they don't fail as often as the cdti's... mine never failed although my mates was replaced @ around 200k.
    Although you're never going to beat any one off the lights, the dti is a decent cruiser & pulls well while on the move... bought mine with 80k & sold it with 155k, other than the usual vac tubes & split boost hose, my only issue was a cv joint.
    May 2012
    United Kingdom
    which hose split on yours? i have a flat spot at 2500-2700 rpm
    Birmingham
    They do, its had a new Clutch and Flywheel.
    Birmingham
    Apart from doing the airbox mod and De-Cat'ing it, can these have anything else done to get some more ooomph!!
  1. Calling all owners! i need help!
    By veccyjim in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 21:30
  2. Calling all v6 owners i need help
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 02:51
  3. Calling all v6 owners i need help
    By dannyjpuk in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 23:17
  4. Calling all you Vectra "design" owners.
    By John LE in forum Styling
    Last Post: 3rd October 2009, 09:41
  5. Calling SRi owners
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 8th December 2008, 11:02
