Results 1 to 10 of 26
Thread: Anyone shed some light on this
    Jul 2011
    UK
    Year : 06
    Default Anyone shed some light on this
    Replaced tear pads and discs but the brake pedal is sinking with my foot on the brake does stop mind do I have air in system
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Did you bleed your brakes after it ?
    Jul 2011
    UK
    Year : 06
    Only the rear near side when disconnected the hose take it all need to do a 4 corner bleed
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    You should only need to do the ones you changed
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    How did you bleed them mate?
    Jul 2011
    UK
    Year : 06
    It lol well I sat it car dad undun the nipple I floored the pedal done it a couple times
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by Mark-R
    That's what I thought
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by marc vectra sri View Post
    hmm - suspect you still have air in the system mate..
    These days I will only bleed brakes and clutches with an Eezibleed... it uses the preasure from your tyre and all you have to do if fill the bottle with new fluid - connect it all up and then just crack the nipple and watch it flow out.. You could also need new fluid in there if yours has too much water polution.
    Jul 2011
    UK
    Year : 06
    Cheers mate how does water get in there did have the cap off during the change is it still safe to drive still stops alright
    Middlesex
    Trim : SRI
    Mileage : 100k
    Happens over time mate hence why a fluid change is recommended every 2 years. Wont have happened during the change so to speak - but over time the brake fluid gets contaminated and needs a change.. With an Eezibleed you can do this on your own no problems..
    If its not been done for a year or two you will defo notice the difference.
  1. Can anyone shed any light on this?!
    By MattyStuart in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2011, 19:18
  2. Anyone shed some light please
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2011, 15:42
  3. shed some light
    By Graeme01 in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2010, 15:04
  4. shed some light
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 22:33
  5. can u shed any light?
    By jun in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 14:42
