Thread: CDTi 150: Has anyone manually removed the internals from the pre-cat pipe?
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Question CDTi 150: Has anyone manually removed the internals from the pre-cat pipe?
    I've got a Scorpion downpipe installed and the fitment is, quite frankly, shocking. So I'm going back to the original pre-cat downpipe but want to remove the baffles first.
    Anyone here done this and have any wisdom to pass on regarding the easiest way to clear it out?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    What i did was used a drill bit on a drill and drilled it out and used a screw driver to pick out bigger bits
    one off these http://www.ebay.co.uk/itm/MACHINE-WO...=bin8265c03dc2 took me 20 mins to do mine while it was still on the car lol
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Ah right that'd do it! Cheers Mark, not sure if I've got one of those lying about but I'll give that a go. Thanks for the direction.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    On another note, whats wrong with the fitment of the scorpion pipe? I was thinking about getting one
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    they are easy to gut takes a bout 2 hours and put it this way i like the way it drives so much am not even going to bother buying an expensive scorpion pre-cat.
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Quote Originally Posted by John IS3 View Post
    It doesn't fit properly, the angle of the flange that joins to the turbo is wrong. They are sold to fit Astra and Vectra on the same fitment but it's clearly not the case. It ends up right against the sump and doesn't seal properly. It's coming out this weekend - my first opportunity to do so...
  1. Removed pipe from the front of airbox 2.0 turbo
    By pipamish in forum Petrol Engine related
    Last Post: 12th October 2012, 22:05
  2. MOT today with HIDs fitted and Cats removed 1.9 CDTi 150
    By merikiito in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 20:38
  3. MOT today with HIDs fitted and Cats removed 1.9 CDTi 150
    By Big-Pete in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2012, 19:13
  4. Can I move EGR manually?
    By krisby in forum Engine & Drivetrain
    Last Post: 25th September 2011, 18:27
  5. Has anyone removed the EGR on a cdti 150
    By jacko52 in forum Engine & Drivetrain
    Last Post: 29th January 2010, 22:45
vectra c cat removal www.vectra-c.com
vectra cdti 150 cat removal
removing pre cat internals
