Thread: Cooling Fan not working?
    Nov 2011
    bristol
    Default Cooling Fan not working?
    Hi all
    I recently changed my thermostat as it was fluctating all over the place. For the first 2 days the temparture gauge stayed at 80c then after that stayed at the bottom and will not move at all despite driving through town or on a motorway or similar, however today whilst idiling after 15 minutes or so it went up to 80c and the coolant boiled over without the fan kicking in or so much as a warning except smoke under the bonnet. I would have assumed the temparture gauge to be in the red for that to happen. Anyone any ideas of whats going wrong? Engine is the z18xe sxi 2003.
    Thanks any help appreciated
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Pull the electrical plug off the thermostat housing and, with the ignition on, the fan should run automatically. Check the fuses under the bonnet, its the huge ones on the left of the fuse box
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    My fan had seized and I didn't realise.
    Mind you, when it did overheat I had the gauge climb into the red, and the fault light come on
    Nov 2011
    bristol
    thanks for the advice i think the problem is the coolant temperature sensor so am going to change that
  1. Cooling fan
    By nokiaman1978 in forum Troubleshooting
    Last Post: 3rd October 2011, 19:27
  2. Engine Cooling fans working correctly?
    By luke4487 in forum Engine & Drivetrain
    Last Post: 28th April 2011, 11:15
  3. second cooling fan isn't working
    By MrBoB in forum Engine & Drivetrain
    Last Post: 16th September 2009, 23:24
  4. Cooling fan
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 00:01
  5. glovebox cooling ?
    By Brake buster in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2005, 20:54
vauxhall vectra cooling fan not working
cooling fan fuse vauxhall vectra c 1.8 petrol 2007
vectra c fan relay location
2.6 v6 vectra cooling fan not working
2007 vectra when does the fan kick in
vectra c cooling fan relay location
where is fuse for radiator fan vauxhall vectra
radiator fan issue vectra c
cooling fan relay on a vauxhall insignia
vectra c cooling fan fuse
my vauxhall vectra c cooling fan is not working what do i do
vauxhall vectra c cooling fan relay
fan not working on vauxhall vectra under bonnet
Signum cooling fan fault
vectra fan not working under bonnet
vectra c cooling fan not working
