Results 1 to 2 of 2
Thread: Vectra 2007 2.8 V6 Turbo IDS Problem?
    Apr 2011
    Denmark
    Default Vectra 2007 2.8 V6 Turbo IDS Problem?
    Hi all
    Sometimes - at random but now every time after a bit of driving the IDS lamp in the dashboard appears and in that instance the suspension gets hard - just like when the car is driving at high speed or when I push the "Sport" button.
    The tester says that there is a fault in the right side - front.
    It says =Trying to translate from danish: Suspension valve - (open circuit)
    Does anyone know what to change or what could be the problem? My mechanic and I have tried replacing the "top" IDS sensor..the one visible from engine room, but no difference.
    Any help or suggestions greatly appreciated
    Jesper
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Check wiring harness at shock absorber and plugs! often there are broken wires or corroded plugs!
  1. vectra c 2.0 turbo 2007 how to realigne the gears ???
    By matrix1979 in forum Engine & Drivetrain
    Last Post: 16th September 2011, 22:42
  2. vectra start up/turbo problem
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2011, 02:41
  3. vectra 150 cdti....turbo problem?
    By trigger in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:53
