Results 1 to 10 of 22
Thread: Some reassurance before I turn the key
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Default Some reassurance before I turn the key
    Have done cambelt and water pump today, and once I worked the tensioner out thanks to the chaps on my other thread, its all gone back together fine. However...........
    .....when I was fitting the cambelt over the cam pulley it suddenly turned about 25* anti-clockwise. It did trap my finger causes a deep wound but thats not the issue.
    I moved the pulley back to the fresh mark I made before removing the belt. The fitted the belt again, this time with no problems.
    Am I right in thinking that even though the pulley moved by re-setting it exactly where it was it should be ok/
    The crank pulley never moved and after rotating the engine twice all the marks line up perfectly and italso rotated freely.
    Cheers chaps
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    Fingers n toes crossed for you chap
    gaz
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Yes you will be fine.
    as long as you put the cam pulley back before attaching the belt there will be no issue. And after rotation if all the timing marks lined up - no issue.
    Did you get the genuine VX cam belt kit? If so the belt has yellow timing marks so you cant go wrong with the positions of the cam / crank easily?
    Sep 2011
    lewes
    Mileage : 125000
    Quote Originally Posted by AntSSSS View Post
    Yes genuine Vx parts.
    Thanks for all your help, this forum is spot on
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by golfpro View Post
    Did you align the yellow lines when you first fitted it - so one on the crank mark - one on the cam pulley at approx 1 oclock and one on the pump pulley (which doesnt actually need to be marked).. You will of course notice that once you turn the crank over with it fitted the yellow markers wont line up again, but as long as the cam / crank are in the correct position at the markers you are cool.
    Sep 2011
    lewes
    Mileage : 125000
    Yes I used the markers, very handy!
    Jul 2011
    Staffs
    Did it work?!
    Aug 2010
    Derbyshire
    Did you turn the key?
    And?
    Hope it's all
    Jul 2011
    UK
    Year : 06
    Maybe he sat with his car crying lol
    Sep 2011
    lewes
    Mileage : 125000
    I'm going to start it tomorrow, been doing the EGR as well and need to pick up a gasket in the morning so will try it after
    You guys are making me nervous lol
  1. DMF Advice & Reassurance
    By Danlisa in forum Engine & Drivetrain
    Last Post: 6th October 2011, 09:36
  2. Turn me on........
    By farmboy91 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2011, 15:23
  3. What happens if i turn this ?
    By Vectra-c-SRI in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 22:37
  4. Oh.......my turn now!!!
    By Caterman in forum General Chat
    Last Post: 23rd August 2007, 18:46
  5. Must be my turn...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2006, 17:42
