Thread: Check Strap Clicking/Knocking Door noise
    milan
    Default Check Strap Clicking/Knocking Door noise
    Dear All,
    three months after replacing the Check Strap of my vectra C, the Clicking/Knocking Door noise is back and stronger, the spare part was original Opel and I assume it would have worked as espected for a long time. The original part number was 9229749 nevertheless I used part number 9229750 as replacement, could you please let me know if those two parts are compatible or the noise is due to a different spare part used as replacement?
    Thanks a lot for your support in advance
    Bye
    Msqualo
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    did you know about this
    taken from another post on here
    OK I can see that no one here has figured this out so here goes the guide from polish Vectra Club (with best regards ):
    Repairing the clunking door stay without buying new one - and without taking it out.
    1. Undo the screw/bolt on the body and move the lever out.
    2. Pull the lever out to full length
    3. Rotate the lever 180 degrees (so the curly cuts will be facing the other way). Yes, you need to apply a little force.
    4. Now undo two nuts from the door side. Dont worry about the bolts - they are securely melted with the stay.
    5. Turn the whole stay once again 180 degrees. It will take about 1 minute to do it right.
    6. Place the bolts in holes in the doors, secure with bolts, secure the lever with the body using last bolt and voila!
    Basically the reason for clunking is that one of the rolls gets worn out, and by rotating the lever 180 degrees you're making the other one do the hard work. Of course, eventually both rolls will be worn out and then you will need to replace the door stay with new one. But this will take about 8 years (I had to rotate the thing after 4 years, so I suppose Im fine for the next 4 years).
    Good luck with that and sorry for my english - apparently it got more rusty during last 5 years than I thought.
    Nov 2010
    East Midlands
    Trim : design
    milan
    Hi,
    I managed to change position of the old clunking door stay and the spare one as explained in the guide and images, that worked out for a month or so then the problem showed up again, thus, there is something else which keep causing the the clicking/knocking issue.
    Any clue, considering that the 180 swap has been performed twice with two parts?
    Msqualo
    Quote Originally Posted by vectra ste View Post
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    http://www.ebay.co.uk/itm/Vauxhall-V...item4cf9953de6
    seems cheap enough to try another
    11 Post(s)
    Quote Originally Posted by msqualo View Post
    Dear All,
    I take it you haven't lubricated it? If you have, then that'll be the likely cause why it's making a noise as the rollers become flat spotted as the oil/grease prevents them from turning when the checkstrap runs between them.
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    My drivers door one is knacked as well. Figure on buying a new one shortly ss well. Are these available under trade club etc?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    milan
    Hi Big Dave, actually your point make a lot of sense, I followed a guide found on a forum which stated to grease the part before fitting it back in place.
    I'll try again with a new part.
    Msqualo
    11 Post(s)
    It gets mentioned in the how2 on here
    http://www.vectra-c.com/forum/showth...=1#post1488692
  1. clicking/knocking noise
    By squiggy4 in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2011, 15:35
  2. drivers door check strap busted
    By valvelift in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2011, 12:12
  3. Door Check Strap!
    By @ndy-e in forum Bodywork & Interior
    Last Post: 5th October 2009, 15:01
vectra c door check strap
vectra c door clicking
vectra c door check strap noise
https:www.vectra-c.comforumshowthread.php165163-Check-Strap-Clicking-Knocking-Door-noise
vectra c check strap
vectra door clicking
check straps for vauxall vectra
check strap clicking
vectra c door stay
car door check strap clicking
check strap door vectra c
vectra c torx for door checksvectra door strap reinforcementcheck strap doordoor clunking vectra cvectra c door clunkingC1 door strap noisefixing noisey door check strap drivers door clicks when opening vauxhall vectravauxhall omega drivers door stayvauxhall zafira door clicking when openingremove passenger front door stay strap vectra 06freelander door check noisyvectra c door limiter clickingVauxhall Astra Front Door Check Link
