Thread: turn airbag light off
    Regular Member krazylegz's Avatar
    South Shields
    Default turn airbag light off
    As above to turn the light off does it need to be done via tech2 or can the other un-speakable one do it?
    ta
    Engine : 1.9 CDTi
    The other unspeakable software can also do it.
    South Shields
    Thanks lee just double checking
    Sent from my iPhone using my fingers n thumbs
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    For info, with the vectra-c system, if theres a loose connection on one of the plugs and you fix it, the next time the car starts and sees it is ok it will extinguish the light itself.. It wont stay on unless there is a fault currently present..
  1. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  2. Airbag light won't turn off
    By ssxanti2 in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 21:49
  3. turn abs light off
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2010, 18:25
  4. Passenger Airbag turn off?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2008, 23:35
  5. Service Light: How to turn off?
    By barkzz in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2008, 19:16
how easy to get airbag light off vectra c
