Thread: egr valve
    May 2012
    rhondda
    Default egr valve
    hi guy's i have a 53 plate 2.2 z22se non direct.
    i have blanked the egr but engine management keeps coming up.
    i have not unplugged the egr just put the blanking plate in between it then bolted it all back down.
    i clear the fault with op-com but it keeps coming back after a few minutes of driving.
    is there something else i need to do or do i just remove the plate and not bother doing it.
    Jul 2011
    UK
    Year : 06
    Needs mapped out I think
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Not on the z22se it doesn't you just leave the EGR connected but tie it away from the engine and blank the hole off (I believe this is the only Vectra C engine this works on). You may find the EGR is faulty which is what the warning's for.
    This is when I did mine on my old saloon http://www.vectra-c.com/forum/showth...-I-m-knackered
    May 2012
    rhondda
    will double check everything as that is the exact same plate as i have
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
