Thread: Really struggling with timing belt tensioner
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Default Really struggling with timing belt tensioner
    Ok so the belt is on and the tensioner is fitted- cdti 150
    I am struggling to get the pointer to the hole. If i lever the tab to make the tension tighter the pointer doesn't move.
    I must be doing something obviously wrong but can't work it out
    Please help!
    Engine : 1.9 CDTi
    Is the tensioner loose so it can move.
    Try pushing it from the other side so the pointer moves.
    Sep 2011
    lewes
    Mileage : 125000
    When i put the tensioner it, the arrow is the bottom, i take it thats how it starts. Push the tensioner all the way out, tighten the bolt and arrow still at the bottom. I take it if I then loosen the bolf the arrow should then move?
    Or am i way off?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    OK - so - are you leavering it using a bolt screwed into the threaded hole underneath the tensioner.
    You need to leaver from that onto the turned out piece of metal on the tensioner at the bottom..
    The arrow will stay at the bottom - then you will get to a point where its tensioned against the belt and it will then rise (quite quickly). Its then at that point you need to tighten it.
    See the pic in another thread I replied too.
    Sep 2011
    lewes
    Mileage : 125000
    I get you know, it rises as you lever, many thanks!
    Middlesex
    Trim : SRI
    Mileage : 100k
    yip... Hold the strain once its in the right spot and tighten.
    then turn the engine crank through 720 degrees (2 complete revolutions) and loosen and re-tension.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Do not over tighten as that can cause failure. I used a mobile phone camera to get a picture square on of the tension, avoiding parallax errors.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by nutron View Post
    LOL - thats EXACTLY what I did:
    Sep 2011
    lewes
    Mileage : 125000
    Just to top of this thread for the benefit of others, you really do have to the lever the tensioner to get the arrow to ping up. I was expecting not much effort! So if you're doing the tensioner and the arrow hasn't moved, give it some more
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    belt ten.JPG its actually done as above & as shown here.
  1. timing belt tensioner question
    By wildchild in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2013, 15:25
  2. Timing Tensioner, head size
    By GCusdin in forum Engine & Drivetrain
    Last Post: 10th October 2012, 21:05
  3. v belt tensioner
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 00:10
  4. Aux belt tensioner on 3.2
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th September 2008, 21:22
