Thread: odd snapping/breaking sound coming from the front brakes
    Regular Member Blurry120's Avatar
    Mar 2012
    Tameside
    Trim : SRI, now with half leather!!
    Engine : 1.8 16v ZXE18
    Mileage : 107,000!
    Default odd snapping/breaking sound coming from the front brakes
    i`ve noticed since the weather has gotten warmer that every now and again theres a sound coming from the front end of the car when braking, its like a metallic snapping or breaking sound, it doesn`t happen every time but it happens either under heavy braking or light braking when slowing down gently to stop, and its usually as the car stops when i hear the noise, now like i say it doesn`t happen every time and its only started as the weather has warmed up, and their is plenty of pad and disc left yet, and being as i can see through my alloys and i can`t see anythin loose, and the car does stop with out any problems i`m just thinkin is this somethin to worry about
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Check your wheel nuts are tight.
    Mar 2012
    Tameside
    Mileage : 107,000!
    i`ve checked the wheel nuts and they are fine, i can`t see the wheel nuts bein the cause of this odd noise tho tbh
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Have you swapped your discs and pads for aftermarket ones (i.e. non-VX)???
    I noticed similar clunking when I bought some MTEC drilled/grooved discs and Mintex pads
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    check that a front coil spring hasnt snapped
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by vectra ste View Post
    i was just away to say that check the springs
    Mar 2012
    Tameside
    Mileage : 107,000!
    Quote Originally Posted by Damo77 View Post
    no its been in a garage to have new standard brake pads and discs fitted way before i bought it
    Mar 2012
    Tameside
    Mileage : 107,000!
    Quote Originally Posted by Mark-R View Post
    yeah i`ll check them later, is it gonna be big money to replace if they have snapped then?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    have a look in detail for any cracks on the coil springs
    best to do them in pairs as well
    Mar 2012
    Tameside
    Mileage : 107,000!
    from what i can see, the springs seem to be fine, so now its left me thinkin, what else it could be
  1. car running lumpy and now strange wooo sound when coming of boost??
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2012, 13:00
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Creaking sound from Brakes
    By mikaz in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2009, 14:40
  4. creaking front when breaking
    By tony whin in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 10:31
  5. Stereo - sound intermittently breaking up
    By johnmac in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2006, 09:05
