Thread: vectra 1.9cdti engine blipping
    May 2011
    sunderland
    Default vectra 1.9cdti engine blipping
    Hi guys my vectra 120 bhp 1.9 cdti on a 06 plate is struggling when smooth acceleration its as tho i am blipping the pedal but when i accelerate hard it doesnt happen ??? Egr valve changed about 3 month ago Any ideas guys thanks in advance
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Sounds like you may need to have the ECU software updated as they newer EGR's function slightly differently than the older units
    There is a VX "Field Remedy" for this:-
    More in this thread mate:-
    http://www.vectra-c.com/forum/showth...2500rpm-Remedy
    Field Remedy: 2149
    Subject:Engine Z19DT/Z19DTL - Jerking in certain rpm rangeModels:Engines:Option:Astra-H ...2006,Zafira-B ...2006,Vectra-C 2004...2006Z19DT| Z19DTL,Z19DT| Z19DTL,Z19DT| Z19DTLonly C9 system and 2 valve enginesComplaint:Customer complaint about engine jerking between 1500-2500 rpm, mostly with 2nd or 3rd gear engaged.Cause:Problem is related to a EGR software deviation.Production:
    Remedy:
    In case of customer complaint reprogram ECU with an improved software. The new software will be available as of CW30/2008 via TIS2WEB(version 8.0) (Only vehicles with MY 2006).Modified software for Vectra/Signum, MT, with and without DPF,as of MY 2004: Available as of 27-Jul-2009!FunctionalGroup:J - EngineComplaint Group:19 - Poor Engine DriveabilityTrouble Code:None
    Good luck
    Damo
    May 2011
    sunderland
    Hi mate sounds expensive any ides of the cost ???
    Year : 55
    Mileage : 92,000
    From what I remember it cost me about £60 (1hr labour) for them to plug the car into their (VX) diagnostics machine. Think the update only took about 5 mins though
    Year : 55
    Mileage : 92,000
    Have you checked all the vacuum hoses in and around the engine for cracks/perishing? Also might be worth whipping off the boost sensor (black box thing located next to the EGR) and giving that a good clean if you haven't done so already
    May 2011
    sunderland
    Not yet but theres always a good smell of diesel tho
    And sometimes it judders when start up
    Year : 55
    Mileage : 92,000
    That could be related to your leak-off pipes on the top of the engine........ I had similar issues to that and replaced the leak-off pipe and starting has become a lot smoother
    HOW-To change leak-off pipes: http://www.vectra-c.com/forum/showth...59#post1678259
    There could really be a number of things I suppose, for example cracks in diesel filter housing (letting air into the fuel supply) loose hose connectors on top of the filter housing (again letting in air) but for me it was just trying to identify which one. Unfortunately that's been the costly bit lol
    May 2011
    sunderland
    Hi Damo 77 just been digging around the engine and i found the pipe at the bottom of the air filter had came out cud this be the reason for the above symtoms thanks again for your advice mate
    Quote Originally Posted by pud wayman
    The pipe that clips into
    The bottom of the air filter housing is just a drain tube there if any water gets in air filter box
    May 2011
    sunderland
    Mmm any ideas wat causing the problems mate??
  1. lowering engine 1.9cdti vectra
    By Milliedog in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2012, 14:11
  2. vectra c 1.9cdti xp2 very loud and ticking engine noise
    By atty in forum Engine & Drivetrain
    Last Post: 26th August 2012, 14:07
  3. After fitting HID: Vectra C 1.9CDTi 150 07 engine warning?
    By DieselHead in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:53
  4. Replies: 9
    Last Post: 7th July 2010, 14:54
  5. Engine nightmare with a Vectra 1.9CDTi 150 on a 05 plate
    By sailingthewild in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:06
z19dt hose air filter housing bottom
