Thread: Rear break help
    Jul 2011
    UK
    Year : 06
    Default Rear break help
    Done one side pads and disc got rewind tool came to do other side and it won't move tried undo nipple nothing just little bit fluid and still won't turn
    Jul 2011
    UK
    Year : 06
    Help am stuck here scratching head
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Have you taken the cap of the brake fluid bottle under the bonnet? Handbrake off?
    If so maybe a stuck caliper / siezed.......Hope it helps buddy and you get it sorted.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Try turning other way a little first
    Jul 2011
    UK
    Year : 06
    Tried that the piston is now out ish undone the hose and clamps and still not
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    A bit of penetrating fluid then keep turhing both ways
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Seized piston by sounds of things.
    Even if you do manage to force it back it'll most likely end up sticking when you start driving. So best just change it
    Admin plasma's Avatar
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    as above, got one thats very hard to wind back in, soo hard in fact that fluid seeps past the piston seal when i do it.... luckily got 2 replacements to go on..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jul 2011
    UK
    Year : 06
    Git it on had another go went on but now the pipe fluid leaking from the bolt
    Jul 2011
    UK
    Year : 06
    Sorted and all on only thing is hand break not very good atal blead them aswel
  1. EH??? Break in wire, rear window demister
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2013, 08:22
  2. rear midle break light not working?
    By sr150i in forum Bodywork & Interior
    Last Post: 1st February 2011, 20:06
  3. Rear break caliper + bleeding screw
    By wakala in forum Suspension, Wheels & Brakes
    Last Post: 20th October 2009, 12:32
  4. rear break problem Vectra Sri
    By universalwoman in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2009, 18:35
