Thread: is this right? mr clutch
    Full Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    Default is this right? mr clutch
    had my clutch done about 5months ago and they told me that in afew months bring it back so they can adjust it. (i thought you dont adjust them)
    anyway,afew months down the line ive noticed that its starting to get hard to get into gear. and i only have alittle bit of clutch.so sometimes i struggle getting it in gear.
    rang mr clutch up and they said bring it down and leave it with us.
    afternoon comes i get a phone call saying its not the clutch thats faulty.. its the master cylinder.... ARE THEY LYING ????????
    Regular Member Greebo's Avatar
    Jan 2012
    In Limbo
    never had to adjust a clutch before, it could be the master cylinder but maybe get a second opinion if you can
    Engine : 1.9 CDTi
    You cant adjust the clutch as its hydraulic.
    It either needs bleeding or the master cylinder is failing.
    Edinburgh
    did the original work come with any sort of warranty?
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    Quote Originally Posted by Big Knox View Post
    yes m8. mr clutch did the new clutch about 5 months ago. but they say the master cylinder dont come under it.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think they must mean the clutch realease bearing. Is the clutch realease bearing on the invoice?
    It should have been changed at the same time as the clutch if not then its likely that has failed, also they may not have bothered changing it but charged you for it.
    The same has just happened to a friend and it was found to the clutch release bearing which again was on the invoice but not changed by the garage.
    Also the clutch is self adjusting so it shows how little Mr clutch know about clutches on Vectras!
    Is the car using/leaking any brake fluid as if it has its a sure sign the CRB has gone.
    The Master cylinder also works the brakes so if they work then I would assume the Master Cylinder is ok? Can anyone confirm that?
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    brakes work fine. and no loss of brake fluid.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Well Mr Clutch in Slough did mine and they changed the full 4 piece clutch kit (LUK ) and Sachs flywheel and gave me all the old parts back.
    they knew the job backwards - were happy for me to even stay and watch if I wanted.. They told me that they do many of these in there differet guize (Saab, Alfa, Vx ETC)..
    No issue with Mr Clutch in SL at all.. You also go back for the first three 500 mile intervals for a check and that keeps your warrant up.
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    well. got my car back... clutch is better than ever now.... cost me a fortune this week.
    £150 on new discs and pads and a new caliper.
    £208 on new master cylinder
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
can i adjust the clutch on vectra c
