Thread: Knock when taking up drive?
    Feb 2012
    Sheffield
    Default Knock when taking up drive?
    Hi All,
    Been searching the forum to no avail so i'm hoping someone might be able to point me in the right direction as to what the knock noise is on my 2002 2.2dti SRi
    When driving along if i back off the throttle and then accellerate again there is a knock noise when it takes up drive like an engine mount or something, someone said it might be the dual mass flywheel? dont think the engine moves so unlikely and engine mount, anyone got any ideas? cant feel anything through the pedals when it does it
    Andy
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Do you get a knock when you disengage the clutch fast too?
    Mine had the same and it was the Driveshafts.. Well - one of the two CV joints and I suspect the inner - but both were knackered so replaced it with a complete driveshaft complete with two new joints from ECP..
    Feb 2012
    Sheffield
    Quote Originally Posted by AntSSSS View Post
    Ah yeah, not thought about that, i once had a diesel focus that did that and it was the CV joint, will give them a check over, thanks!
    Middlesex
    Trim : SRI
    Mileage : 100k
    grab the driveshafts with the wheel off the ground and see ifyou have excess in and out movement - bet you do
    Edinburgh
    you could leave the handbrake on and rock the engine with the clutch to see if it is engine mount. Also visually inspect the mount hasn't become loose (had this after my DMF was replaced, tightened bolts and clunk disappeared.)
    Feb 2012
    Sheffield
    Christ! i hope not going away for the week on saturday in it! was just going to drive it gentle till i got back but i think i need to check this out first...
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    This sounds like what happened to me. Went to 3 mechanics, was told rear engine mounting.. bull. Gear linkage gone and syncro mesh...
    Was the left hand inner cv joint for me. .
    tested it Putting the car in 2nd gear with handbrake off. then by pulling the car towards me until it engages and then push her back a bit. Its not a nice noise if i recall correctly.
    Hope you get it sorted quick enough though..
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    wishbone bush / drop link/ broken spring / strut top mount or lower ball joint ?
    just a few other things to tick off the list
    Regular Member daz-b's Avatar
    Nov 2011
    grantham
    Vehicle : insignia sri vx line
    Trim : vx line
    Engine : 2.0 cdti 160
    Year : 2011
    Mileage : 57000
    i'v got the same problem knocks when i accelerate and when i let off the pedle, been tryin to find out where its coming from for months now, keeps us posted if you find out what it is, i'm goin to have another go at the weekend so i'll keep everyone updated.
    Feb 2012
    Sheffield
    gee thanks for that! lol
  1. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  2. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  3. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  4. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
  5. Knock/Clunk when taking up drive Rev/Fwd + Squeak from Front N/s ??
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 18:40
vectra c knock.when release clutch
knock on drive take up
vectra c when driving knock noise when releasing clutch
