Results 1 to 10 of 15
Thread: springs
    Regular Member kev smith's Avatar
    swindon
    Default springs
    I also got a full set of vectra c 3.2 gsi 2003,springs for sale,i believe the gsi's sit 20mm lower than some other models so could be good for someone???? im looking for £50 for the set,can post but collection would be easier?
    thanks kev.
    Regular Member Patrick's Avatar
    Jun 2006
    Singapore
    will it fix a 1.8 veccy? I'm looking to lower my ride.
    swindon
    Quote Originally Posted by Patrick View Post
    im not 100% sure i should think so?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Check your front axle weight mate compared to the Gsi...
    Regular Member Ian's Avatar
    York
    Quote Originally Posted by CDTi View Post
    Tis true - my mate fitted some springs to lower his cav turbo, front sat up back sat down!!! - fitted them to my V6 and nice n level.
    swindon
    make me an offer if interested need to get rid need to make some space.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Should fit the 3.0 CDTI axle weight as well wont they?
    Jun 2006
    Singapore
    i really got no idea where to check the front axle weight, any one able to guide? if someone promisingly tell me if can fit my 1.8, i will like to get it.
    tks.
    patrick, the number you need is on the black sticker that has the vehicles Identity number on it..normally found in the drivers door area around the area of the lock on the body frame.. there should be 4 numbers.. two of type 1 and type 2..axle 1 is the front, axle 2 is the rear .. one is unloaded, the other is fully loaded.. what you need is the 1st number 1 figure..
    Jun 2006
    Singapore
    great, i will check it up tomor morning, is quite dark now, (we are 8 hrs ahead of you)....tks mate.
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
