Results 1 to 10 of 19
Thread: Clutch and dmf replaced :)
    Jan 2012
    Somerset
    Default Clutch and dmf replaced :)
    Had the above done today and is loads better..!
    One little issue is when initially pulling away it makes a slight noise like a cooing then it doesn't do it again.
    Is this normal when first been fitted or do I have an issue and need to take it back?
    Jan 2012
    Somerset
    Just an update.
    Took it back to the garage today and they think I might have a dodgy clutch and they don't think the friction plate is sitting flush. Told me to give it a few weeks to see if it improves if not will have to take it back out and send it back off to be inspected
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    What make was the clutch - and did you have the full kit?
    Jan 2012
    Somerset
    Was luk 3 piece kit and Sachs flywheel at the same time
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have not heard of a 'dodgy' unit before but bad fitting is not uncommon. You should have no noises from the clutch but it might slip a bit when bedding in.
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Isn't that "cooing" noise the release bearing? that shouldn't be the case if all new kit was fitted.
    Jan 2012
    Somerset
    I know all the bits were fitted as I requested all the old parts do I could check. It's kind of like a little squeal when your pulling away and reversing. Almost sound like a sticky calliper noise but it's not.. (if I make sence)
    Jan 2012
    Somerset
    Is there any cheap easy way to find out if it's not been fitted right without me paying someone to strip the whole lot out?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Sorry - just to be clear did you have:
    New CSC
    New Clutch Plate
    New Presure Plate
    New release bearing
    i.e. 4 bit.
    Jan 2012
    Somerset
    Yes had the whole lot replaced
  1. Where to get the Clutch replaced?
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 22:50
  2. 3.2 clutch slipping so being replaced, flywheel options?
    By merge in forum Engine & Drivetrain
    Last Post: 28th May 2011, 16:20
  3. clutch replaced but now extreme banging!!
    By Jow20 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th May 2011, 13:44
  4. Replies: 31
    Last Post: 18th January 2010, 18:12
  5. DMF + Clutch replaced, now loss of power
    By yzf1kr in forum Engine & Drivetrain
    Last Post: 28th July 2009, 21:07
