Thread: Alternator help!!!
    WOLVERHAMPTON
    Default Alternator help!!!
    Chaps.....following the how to and was all going so well however after unbolting my alternator it refuses to come out!
    It is a 120 with only 2 bolts and both are out. There is some sort of collar on the top one. Do I have to pull this out or drive it in to release the thing?
    Any one have the answer for me?
    Sitting at the side of the road scratching my head!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Are you sure its not the same as the 150 where there is also one bolt the belt side..
    you need to remove the two bolts at the top and the little bracket they go through to get the top to come free (again if its the same as the 150)
    A
    WOLVERHAMPTON
    Thanks for the reply Ant
    It is different. Gotta wrap up soon so can see me back here tomorrow.
    Will post a picture later.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    There are only 2 bolts and some sort of collar on the 120, 2 of us changed mine about 18 months ago. Freed it in the end, but I can't remember how, sorry. We loosened the fuel filter crash box to give a bit more room, it can be removed completely but we found it wasn't necessary to do so.
    WOLVERHAMPTON
    Thanks Folks
    Job done now. The alternator was just really tight in the mount and swivelled as if something was holding it.
    BTW the helpful guy who sold me the alternator..(another Denso 105A) advised on charging the battery fully off the car and not letting the alternator do it as it might end up knackered pretty soon again!
    Might treat myself to a 140A alternator ready for next time!!!
    Car had done 108K but I have only had it from 83K but all the looms still looked like manufacturers fixings so maybe it is the first change?
  1. New Alternator
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 00:50
  2. which alternator
    By john1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2011, 13:32
  3. Alternator
    By m8wos in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  4. what alternator do i need?
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 14:50
  5. alternator
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:01
