Thread: Bought new cd30 and screen....
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Bought new cd30 and screen....
    K, got a small crappy display as I mentioned before, new screen fitted and car went crazy!!! Removed full screen and replaced with old one....
    Now I purchased full screen with paired cd30 that have a way better condition to my current cd30!!!
    It's not here yet as I just bought it...my question is...
    Is it a straight swap of the removal of screen then headunit and swap over to the new one I bought?? This unit is supposedly came off a 2006 1.9cdti which is same as mine, will it be fine? Do I need any further adjustments using the computer connected to car which I have.???
    Help would be greatly appreciated guys.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Providing the headunit and screen are paired already it should be a straight fit.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    It shown in photo paired and the lady wouldnt know about divorcing. Lol
    My car have TID so will I need to adjust settings or does the head unit hold all info?? Just being clear on that :-)
    Regular Member krazylegz's Avatar
    South Shields
    If your car only has a TID then the pug will be different and wiring will need changing for a GID
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    The plug in back of screen is of the gid connection. The car had a gid removed before he put it up for sale.Dark blue plug.Seen on photo a grey plug for TID so I'm safe.
    South Shields
    Sod knows then lol
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if you are swapping both HU and Screen as a pair they will work fine together, i did a cd30 to cdc40 pair straight swap and it all works fine and dandy
    HTH
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by ditchp View Post
    HTH
    works a treat. button controls works as it should. i checked to make sure it matches the car spec and it came from 1.9cd red TI 150 like mine. same model as well.
    but i posted a new thread about safeguard. as it must be a separated due to different issue? i will check the alarm sensor by the maplight as it was with the mapreading light/sunglasses storage i bought 1 month after i bought the car.
    good job, i still have the old one so i will try the alarm thing and swap them over to the new one and hopefully see the fix??
    Jan 2008
    ipswich
    i just brought a screen and a new radio for my motor and it came up on mine too
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by johnboyna54
    I need a link to disable the washer level sensor if anyone know? Using tech2 or similar
  1. For Sale: CD30 and screen
    By Rob12 in forum Parts for sale
    Last Post: 21st September 2012, 11:25
  2. Cd30 and screen
    Last Post: 13th May 2012, 18:53
  3. cd30 screen
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 21:27
