Results 1 to 10 of 13
Thread: Smoking fan
    Sep 2009
    Glasgow
    confused Smoking fan
    Hi all, my blower fan has been playing up, it works on all speeds, but it's seems to be holding back on speed 4 it speeds up slowly but not quite full speed, the rotation speed seems to fluctuate also on setting 4 smoke starts to fill the cab, today i stripped it again and this time used a syringe to force grease into the motor bearings, motor is moving at correct speed again, but the smoke on setting 4 still remains, there was a bit of grease around where the power plug goes in would this cause it to smoke, also resister pack is fine.
    What state is the pollen filter in?
    Sep 2009
    Glasgow
    new one last week bud drain holes all fine no signs of water damage.
    Sep 2009
    Glasgow
    bump
    Sep 2009
    Glasgow
    anyone
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    hi nokiaman 1978
    have a look at post 16
    http://www.vectra-c.com/forum/showth...squeaky+heater
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    i think the previous owner of your car had the scuttle leak through the pollen filter
    and the water has taken out the grease causing it to smoke
    this may help
    http://www.vectra-c.com/forum/showth...ghlight=heater
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Sep 2009
    Glasgow
    IMAGE_210.jpgthis pic is from another post........... cleaned out fan motor today, noticed the copper wire that goes into the spring loaded bit had perished, also there was a wedge of some sort of metal at the left next to the coil of copper, im assuming this bit of metal has worn and moved away from the spring loaded part and the copper wire has come loose, i removed the spring and place the copper wire so it was touching the motor and put spring back in , it worked great for about 10 min and then i was back to square one, are these parts available or is it a new motor, i think its one of the bushes that have went, unlike the pic, i have a small plastic clips holding the spring in, so hopefully it's designed to be fixed.
    Quote Originally Posted by nokiaman1978 View Post
    I would doubt just the part you require is a available
    You may be able to source one from a scrappy
    Otherwise it is a new one
    I had a similar issue with the ventilation motor on my Rover
    The part I required would cost about £10, but wasn't available separately, so it was a complete new assembly
  1. Smoking
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 17th January 2012, 11:24
  2. smoking
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2010, 19:21
  3. smoking
    By dominic32 in forum Engine & Drivetrain
    Last Post: 24th June 2009, 23:20
  4. Smoking
    By lizard in forum Styling
    Last Post: 18th January 2008, 21:21
  5. No Smoking
    By VauxVeteran in forum General Chat
    Last Post: 8th July 2007, 12:01
