just after a bit of info my wifes vec b has started with an oil leak from where one of the injectors (or tubes) goes into the head had the rocker cover off last night and the tube (or injector) is bolted at the inner end so took the bolt out but the tube thing is loose but won't come out,it sits under the camshaft but does'nt have anything to do with it
has any one any info on if this part will come out without any damage to anything or does the camshaft have to come out
help needed please!!!!!
Steve
