Thread: A/C problems. Hissing and whining noise
    Nov 2010
    Oxford
    Default A/C problems. Hissing and whining noise
    A few days ago now the hot weather kicked in I decided to give my AC a blast however I noticed as I pulled up in my drive it started making a loudish whining/whiring noise. The noise is only present when the A/C button is turned on and stops when I turn it off. I also noticed when I tested it today that there is a hissing Noise coming from the centre vents. It's most obvious when the engine is idling and you press the AC button there is no need to turn the fans on. The noise gets louder as the engine revs. The AC is cold but not as good as what I would expect. The side vents seem to get a lot colder than the centre vents
    Is it likely it just needs a regas or is it likely to be more serious. Is there anything I can do to troubleshoot it as my other half has had her hours reduced so things are tight and I can't afford to spend hundreds on AC repairs right now
    Any help would be appreciated.
    Thanks in advance
    11 Post(s)
    Quote Originally Posted by Azy View Post
    Firstly, AC should be used all year round, not just on hot days. Also makes for a great demister in winter when used with the heater.
    Little use causes the rubber seals to dry out and thus the refrigerant can escape.
    The noise could just be due to the system being low on gas and PAG oil and not being enough to lubricate the AC compressor.
    Kwik Fit don't charge if there is a leak, and charge £49 to top up. ATS also offer a top up service - slightly cheaper at £44.99 and again claim not to charge if the system isn't ok. Both use a plug and play machine that an untrained chimp could operate.
    Full Member
    Mar 2011
    n. ireland
    on the same theme not to hijack the thread! yesterday my ac didn,t seem just as cold as previously, like you dave i use mine in the winter months to help demist as per hand book, so do you think time to regas? it was done when i bought the car 16 months ago
    Nov 2010
    Oxford
    Thanks for your reply. I don't use it a lot during the winter but do periodically for demisting windows and what not. Is it likely the gas has come so low to be making such noises Without a leak in the system, I hear stone chips to the compressor is common with the vectra-c
    GLASGOW
    Default Air vents
    Sorry to hijack this but i cant post a new problem iv got a vectra c cdti but its no air coming from the dashboard air vents but the windscreen one is ok so are the feet vents any help please thanks
  1. Problems - whining noise coming from 5 gear
    By toughmat in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd September 2011, 08:50
  2. 19CDTi Hissing Noise under acceleration???
    By Missimaxo in forum Engine & Drivetrain
    Last Post: 21st September 2010, 09:47
  3. Hissing noise 2.2DTi
    By Celes in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 22:13
  4. Hissing noise when engine switched off.....
    By s0501291 in forum Engine & Drivetrain
    Last Post: 26th April 2009, 01:17
  5. hissing noise
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2008, 22:51
car aircon making hissing noise vectra
vauxhall vectra ac makes hissing noise at start but not leaking
noise when ac turned on vauxhall
2012 escape ac making howling noise
