Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: How to check discs
    Jul 2011
    UK
    Year : 06
    Default How to check discs
    How do I check I need new discs mother in law say don't need them bla bla the rears I know as they are grooved and ribbly but how do I check the front thanks
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    the same as the rears, but most importantly the thickness, will tell you if they are worn
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by phil67
    What's the thickness ment to me the fronts are smooth no lines on the face like the rear
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    I did a quick search and this may help
    http://www.vectra-c.com/forum/showthread.php?t=139088
    Jul 2011
    UK
    Year : 06
    Cheers mate so any less and new disc needed
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Ideally with pair of vernier calipers or similar.
    But as long as theirs no major scoring, blueing an no big lip on the edge of the discs they SHOULD be ok.
    Depends on what discs are fitted
    Basically, take the measurement stamped on the edge and deduct 2mm
    On my 314mm discs, they are 28mm new and 26mm minimum
    However if you know the history of the disc, then you can take them to about 2 or 3 sets of pads
    I have had 3 sets of pads on mine, they are about 23mm (and clearly showing signs that they are at the end of their life)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    There is usually a cut out in the outside edge of discs that is basically a wear indictor, once you reach it its time to change. I'll see if I can find a pic of what I mean.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    There are some define measurements in which they recommend changing of the discs and dont forget the pads when you do the discs.Try doing a search on here, im sure ive seen it somewhere matey
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
  1. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  2. For Sale: RAC Car Data Check (similar to HPI Check) - £10.00
    Last Post: 29th July 2011, 08:49
  3. RAC Car Data Check (similar to HPI Check) - £10.00
    Last Post: 18th March 2011, 13:43
  4. Replies: 1
    Last Post: 21st October 2008, 15:11
  5. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
