Results 1 to 10 of 16
Thread: Clutch slipping and loosing clutch/brake fluid
    coatbridge
    Default Clutch slipping and loosing clutch/brake fluid
    Hey, my clutch has been slipping for a few weeks now quite badly, I'm now loosing clutch/brake fluid but it's not going onto the ground and there isn't any visible signs of a leak.
    Is there any common problems in this area or does anybody have any ideas on what it could be ?
    Thanks Martin
    Regular Member signumturbo04's Avatar
    SCOTLAND
    most likely to be the concentric slave cylinder thats leaking, this can cause brake fluid to contaminate the clutch and cause it to slip. have a look where the gearbox meets the engine block under the car to see if it looks damp
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'd agree with above most likely slave cylinder leaking an contaminating friction material of clutch
    coatbridge
    Thanks guys, I had a look under the gear box but there isn't any sign of damp spots anywhere, could still be the slave cylinder though couldn't it ?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I'd say it's more than likely. As clutch slipping too.
    But double check no signs of leaks above brake pedal.
    coatbridge
    defo no sign of leaking anywhere, will the fluid have destroyed the clutch aswell? or if I fix the slave cylinder will it dry out? probably a stupid question
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It will have killed the friction material aswel
    An tbh the labour involved in splitting to change slave cylinder you may aswel do clutch as well
    And of it has dual mass flywheel that too because of clutch has been slipping its guaranteed to have affected that
    coatbridge
    ok thanks for your help mate, how much do you recon it will cost ?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Not sure tbh mate different places offer very different prices
    You'll probably find a clutch/ transmission specialist will offer best price
    Id say roughly £800 but seen people get it for as low as 550 an upwards of 1100
    As a guide I paid £747 trade price for parts f(2 piece clutch kit,DMF, CSC) or my v6 cdti
    and took me 9 hours to fit. (book time is 7 hours)
    coatbridge
    God that's silly money for a clutch, mines only a 1.8 SRI I'll check some prices
  1. Slipping clutch..
    By Steven in forum Engine & Drivetrain
    Last Post: 20th July 2011, 09:00
  2. loosing brake fluid
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2011, 17:33
  3. Gearbox/clutch/brake fluid change-TOMORROW!!
    By nikroc in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 22:49
  4. Brake and clutch fluid change questions.
    By James24 in forum Handling & Braking
    Last Post: 9th June 2009, 15:15
  5. Slipping Clutch
    By kel123 in forum Engine & Drivetrain
    Last Post: 12th July 2008, 11:16
