Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Revs itself whilst idling.
    Aug 2011
    Leeds
    Default Revs itself whilst idling.
    Hello all, first sorry for my first post being a problematic one but here goes.
    Car is 2006 and lately while idling and only with aircon or fans on, it will idle normally then say every 30 seceonds to a minure it will rev till about 900rpm then back down and the engine will vibrate a little.
    I opened the bonnet and the fans at the front will be running (only with aircon on) and the valve thing that moves above the turbo will slightly open and shut.
    Car drives fine, only other issues, although doubt its related is slight DMF rattle at idle and slightly blowing flexi pipe.
    Thanks in advance for any replies!
    Regular Member John Bishop's Avatar
    Oct 2010
    Does instant MPG increase?
    Aug 2011
    Leeds
    Instant MPG is 0.2 at idle and about 0.4 with aircon on, and no I dont think it increased while it happens, definetly not to 1.0, as I checked incase it was trying to regenerate.
    Oct 2010
    That was first thought
    PRESTON
    Check the alternator is putting out at least 13.5 to 14volts at idle, car revving by itself is a sign the alternator on the way out.
    Aug 2011
    Leeds
    Thankyou, will try and get it tested tomorrow.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Worth Taking car for a good thrashing.
    Not speed. REVS need to be at least 4000 revs for good few miles
    The v6 seems to get coked up really easy an start chocking its self.
    Mine hunts every so often only up an down a small amount of revs but just needs good Italian tune up an everything will be fine agen.
    Also as mentioned check batt and alternator as one could failing an the added current draw from aircon pump causing it to struggle
    Regular Member mat_splat's Avatar
    May 2012
    Frimley
    I had this once before just after a very flat battery. Throttle position sensor needed to be reset. I just floored it and let it off. That stopped it. Just a thought.
    Aug 2011
    Leeds
    Cant get it checked till weekend, had more of a check and thinking something to do with aircon since it just does it with aircon on, even when the fan is on zero. Had new waterpump fitted not so long ago, not sure if they disturbed something while poking around.
    Btw anyone had software updates? Not sure if any were brought out and to my knowledge none have been done.
    Aug 2011
    Leeds
    A little update, got the car serviced with fuel filter change and the voltage checked which was all fine but its now doing this even with the aircon off. Will cleaning the throttle body help this? Looks a little tricky to get to.
  1. 2.2 idling
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:00
  2. Idling
    By Daywalker in forum Engine & Drivetrain
    Last Post: 10th May 2008, 08:23
  3. Eratic idling
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2008, 21:08
  4. Idling At 1200rpm Whilst Coasting
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2007, 11:47
v6 vectra revs up and down on its own
vauxhall vectra 2007 when idle revs itself
vauxhall vectra revs itself
