Results 1 to 3 of 3
Thread: Reverse Sensor Volume
    WAKEFIELD
    Default Reverse Sensor Volume
    Just got some reverse sensors fitted from Vauxhall,they have used xvision parking systems.
    They are working fine but i just think the warning tone volume is just on the low side,does anyone know if you can up the volume.
    Just can't be bothered doing a fourty mile round trip if it's something that can be easily adjusted.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    On the kits I have fitted there should be a volume adjustment wheel on the main control box. Usually the control box will mounted somewhere close to one of the rear lights where it will get it's feeds. I would try and locate it around there failing that give the delaers a call and ask where they locate the control box and you could do it yourself to save the trip.
    WAKEFIELD
    Thanks for that will have a look in the morning.
  1. Gadgetman reverse sensor wiring help required
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 13:05
  2. Parking sensor - which wire is reverse?
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 22:41
  3. Reverse sensor kit GM
    By blue estate in forum Parts for sale
    Last Post: 19th March 2008, 21:46
  4. Just fitted my Reverse Sensor
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2008, 21:37
  5. Reverse sensor wiring.
    By 2ltrT in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2006, 21:24
xvision parking sensors volume
