Thread: 3.2 Veccy C rough Idling
    Aug 2011
    Brisbane
    Default 3.2 Veccy C rough Idling
    Hi Guys
    Car got idling problems, when air conditioning is on idling's good but when its off rpm drop and becomes rough, needle spikes abit. Also its eating up more fuel then normal, on a full tank i would barely crack 450k's. Any advice would be great.
    Mechanics reckons the injector harness as shown in pix below needs replacing, they zipped tied it together. Could this be the problem and does anyone know the part no. for the whole harness??
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'd look at 'cheap' fixes first.... breathers cleaning, air filter, spark plugs, fuel filter and some fuel system cleaner would be better things to do and could also be considered normal periodic servicing. If that cable tie is doing the job in holding the two halves of the connector together, then as long as the connections inside are working, changing it is pretty much a cosmetic exercise.
    Aug 2011
    Brisbane
    Yea I checked all that but still no change, cheers for that though
    May 2012
    chelmsford
    Could be Check lambda sensor mate. Take it for a good thrash and see if that does it
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Hey Mark,
    Disconnect the MAF sensor, and see if it makes any difference. If it doesn't, the MAF sensor could need a clean in some isopropyl alcohol cleaner.
    Also, your inbox is full. Just a heads up. You can now sign up to OpelAus with a free email account. Hope to see you over there
    Chris
    Aug 2011
    Brisbane
    Quote Originally Posted by Vectra_C_Chris View Post
    Hey Mark,
    Chris
    Thanks Chris, just researching how to clean the MAF.
    Yea i just deleted msges in my inbox but sweet will hit up opelaus.
    Also went to check my Oil and the whole plastic attached with the oil cap came off, is it just glued on??
  1. Replies: 3
    Last Post: 7th June 2012, 15:42
  2. 3.2 Veccy C rough Idling
    By maleko in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2012, 08:32
  3. siggy 1.9 cdti rough idling
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 11:47
  4. Rough Idling
    By iainm in forum Engine & Drivetrain
    Last Post: 12th August 2009, 22:51
  5. idling rough
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 16:21
