Thread: Pins 17 - 35 on quadlock
    May 2012
    cheshire
    Default Pins 17 - 35 on quadlock
    Any picture diagrams on the pins 17 - 35 on the quadlock connection?
    Many thanks
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    There is a picture here of the top of a CD30, but not much info.
    http://www.vectra-c.com/forum/showth...hp?144942-cd30
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    which picture you after m8 is it 1one that shows what wires go to the pinouts or a picture of
    an actual quadlock radio plug ??
    May 2012
    cheshire
    Thanks was just after finding out which go where.
    But found this earlier.RADIO CONNECTIOS ARE AS FOLLOWS: -
    Radio Connections for 2004 Onward…CD30, CDC40, CD70
    Radio Pin No Colour Function Goes to: -
    1 white speaker wire speaker loom
    2 yellow speaker wire speaker loom
    3 blue speaker wire speaker loom
    4 green speaker wire speaker loom
    5 brown/white speaker wire speaker loom
    6 brown/yellow speaker wire speaker loom
    7 brown/blue speaker wire speaker loom
    8 brown/green speaker wire speaker loom
    9 GREEN HI SP’D CAN GID pin 22 (should be 20)
    10 WHITE HI SP’D CAN GID pin 23 (should be 19)
    11 Black Telephone
    12 Brown ground Chassis ground and GID pin 24
    13 red/white data link twin audio / travel assistant
    14 white speaker wire speaker loom
    15 RED +12V Instrument Fuse (FI1)
    16 yellow speaker wire speaker loom
    17 blue/red data link Twin Audio/ Travel Assistant
    19 sheath data link Twin Audio / Travel Assistant
    20 Grey data link Twin Audio / Travel Assistant
    23 green/white data link Twin Audio / Travel Assistant
    29 sheath Telephone Microphone
    30 orange/grey Data link Air Bag and Telephone
    31 green/brown data link DAB unit
    32 Blue/red data link DAB unit
    33 YELLOW GID LINK GID pin 9
    34 Blue Telephone
    35 Blue/red Telephone Microphone
    37 BLUE/RED Speed sensor ABS pick-up
    38 Sheath Data link DAB unit
    39 BLUE GID LINK GID pin 8
    40 Brown Telephone
    For the VGA wire colours please see post referring to GID pin-outs above.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yep - that is one of my posts, but do be careful, especially with the Aux-in wires, as these are different between the CD30, CDC40 and CD70
    But these are the listings from TIS2000 wiring diagrams
    I have actually noted that pins 9 and 10 are actually Mid-speed CAN, not High Speed CAN as written in the list.
    CD30 will mention 3 pins with "RSA".
    Now I have never actually found written confirmation of what RSA means / stands for.
    And the twin audio is not for all radios either.
    Only CDC40 is capable of DAB.
    If it helps, I run a CD70 Navi and Colour Display.
    When I fitted it in place of a CD30 and Triple Info Display, it had no wires whatsoever in 17 to 40 and it worked perfectly.
    I have since inserted wires for a telephone, as I also fitted a Nokia car kit.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Google suggests Rear Seat Audio, with RSA SWC being a switch.
    But, if it is Rear Seat Audio, (twin Audio) is it an output to another amplifier by the rear seats??
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by TonyP2020 View Post
    ive just retro fitted twin audio to me signum,the wiring goes from the head unit then direct to the twin audio unit at the back of the console
    think theres something like an amplifier in the twin audio unit but it may be more like just a switch panel as it might be amplified in the head unit
  1. CD70 Quadlock
    By keefy*2010 in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 17:57
  2. canbus quadlock - iso
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2008, 22:15
  3. Quadlock to iso
    Last Post: 24th September 2008, 22:14
  4. NCD 2013.... ISO or Quadlock?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 01:21
  5. Swapping stereo from one with ISO to new one with Quadlock
    By Ben H in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2006, 21:44
vectra c cd70 navi quadlock pins
rsa swc cd30
