Thread: 3.2 V6 Gsi Rough Running From Cold
    NEWCASTLE UPON TYNE
    Default 3.2 V6 Gsi Rough Running From Cold
    GOT A BIT OF AN ISSUE WITH MY MOTOR, WHEN I START IT FROM COLD IT RUNS LIKE A BAG OF S**T FOR ABOUT 30 TO 40 SECONDS THEN EVENS ITSELF OUT. IT'S JUST LIKE IT IS ONLY RUNNING ON 5 CYLINDERS FOR THEM 30 TO 40 SEC'S. AFTER THAT IT'S FINE, ANYBODY HAD OR GOT THE SAME PROBLEM????????
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    sounds normal
    Mileage : 000
    Yes I belive one or two other members have had a similar "problem", GSI 3.2 will be along soon and put us in the picture, but why it happens I am not too sure about.
    Ahem... Thank you ed....
    It sounds like you have the classic overfuelling that effects the V6.. Now modern cars don't have a choke to speak of, the rely on getting a cold engine running by throwing in loads of fuel for the 1st minute..it's this flooding that may be 'snuffing' out one of your spark plugs.. this condition can be made worse by a slightly faulty coolant temperature sensor, as it tells the engine it's cooler than it really is.. you will also find that it happens more now the weather is getting cooler..If it was happening all the time, i'd be looking at coil packs or a duff plug...but as it's only on initial startup i'm sure that you've got the overfueling issue..
    as long as it runs okay and dosen't stall while it's rough running, i'd leave it..getting VX to sort it would be hard as they will have to re-create the issue in their workshops, and then try and alter the fuelling map..something they won't be able to do at your dealers..
    blimey you've been reading up on that aint ya mark ??
    thats the 'simple' explanation mate.. i haven't even started onhow the EGR system affects the initail running either.....
    SAD??..... Yep..
    Regular Member Gazza90000's Avatar
    Newcastle upon Toon
    It sounds like you have the classic overfuelling that effects the V6.. If it was happening all the time, i'd be looking at coil packs or a duff plug...
    Gsi has got this spot on. You could be unlucky and have a Audi/VW.
    I had a Audi TT b4 my Vec and don't get me started on coil packs. Audi/VW would still not admit after replacing 4 Coil Packs that thier Coil Packs were defective.
    Parking outside all night in this weather and living in Newcastle is damm cold and can be expected I suppose....
    Last edited by Gsi3.2; 13th December 2006 at 22:23. Reason: missing brackets on quote
  1. signum 2.8 Rough Running When Cold
    By viper8 in forum Engine & Drivetrain
    Last Post: 7th August 2012, 23:15
  2. Cdti rough running on cold start up
    By brimfull in forum Engine & Drivetrain
    Last Post: 19th January 2012, 20:16
  3. sri 150 running rough on start up help?
    By danni_kitch in forum Diesel Engine related
    Last Post: 26th September 2011, 13:30
  4. 2.2 Sri Direct - running rough
    By johnmac in forum Engine & Drivetrain
    Last Post: 24th December 2007, 19:12
  5. Rough running with KaN air filter
    By Kcs in forum Engine & Drivetrain
    Last Post: 21st February 2007, 22:45
vectra c 3.2 v6 water temperature sensor and hard starts
signum 3.2 v6 running rough
3.2 signum running lumpy
