Thread: Headlamp manual leveling doesnt work... is that an MOT failure?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Headlamp manual leveling doesnt work... is that an MOT failure?
    Any ideas? Although I only tonight noticed the problem randomly as I arrived a little early to pick the wifey up and ended up playing around with the switches etc...
    2008 (MY57) 1.9 (120) - Halogen Lights
    1. Is it an MOT failure? I'm hoping not as its only just had an MOT 3 weeks ago?
    2. The fuse for the motors looks fine, although I cant hear the motors move when I use the level switch.
    3. I'd think it would be a bit random for both motors to go at once, but is there a way to test them if I take them out?
    Thanks!
    Jan 2012
    Milton keynes
    Mileage : 38100
    Morning bump!
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Not sure matey I should imagine if they are set to the correct level u will be ok how ever if you have a car full of people you are not able to adjust them must admit never sin a Mot tester adjust mine to see if they worked
    Jan 2012
    Milton keynes
    Mileage : 38100
    I've googled the hell out of it and cant seem to find a reason other than both motors are tits or the switch has gone u/s...
    Doesnt seem to be a MOT failure by the look of it, they only check the angle on the Halogen lamps, and reading up on Xenons, if the car is fitted with a self leveling system they normally have no way of testing to see if it is working so have to give the benifit of the doubt anyway... ?
    Full Member Big Sig's Avatar
    It's not a failure as not all cars even have the facility to adjust them from inside. Maybe it's the switch that's gone?
  1. radio doesnt work
    By mtqn in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2012, 02:40
  2. key fob on mk 4 astra doesnt work
    By tyler boy in forum The 'Off Topic' room
    Last Post: 2nd July 2011, 20:25
  3. Fan doesnt work on position 1
    By martinmack in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 21:38
  4. car kit doesnt work since i changed hu?
    By EURO G in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2008, 17:19
