Results 1 to 10 of 13
Thread: Double click/Deadlock
    Question Double click/Deadlock
    Just discovered this afternoon that double clicking my lock button doesn't dead lock the doorpins down like it used to on my Astra G - is this right? If not will warranty cover it?
    If this is normal, then I can't understand what the point of the second click is, the solenoid definitely makes a noise when I do the second click.
    Anyone able to give me a clue before I go and make a fool of myself at the main dealer?
    Regular Member chrismiller's Avatar
    they dont on mine just make the noise of deadlocking was the same on my 3 series bmw
    Regular Member C19_CJB's Avatar
    Beverley, East Yorkshire
    hmmmm... good question
    I know that mine makes the noise but i've never tried to pull the pins after I have locked it.
    I will give it a go at lunch and let you know.....
    Chris.
    Forgot to mention in the original post.... if I pull the pin up (after apparently deadlocking the doors with the second click) it unlocks the door and I can open it with the handle, so the deadlock isn't doing anything at all.
    just tried mine sat in deadlocked pull up the button and nothing wont open any doors no matter what you do until the remote re-pressed hth..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Deadlocking on mine has same effect, ie can pull the button up, but car door will not open (hence deadlocked)
    Do none of your doors do this??? or is only one defective?
    All of the doors appear to be the same - if i lock them and deadlock I can still unlock using the doorpins???? sounds broken to me... gonna have to see what Vx say.
    Get it in to Vx mate.
    ECU reset, all works fine.... simple as that!!!!
  1. how do you overcome a deadlock
    By vxr in forum Bodywork & Interior
    Last Post: 4th October 2018, 13:53
  2. Deadlock not spring?
    By Thomza in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 15:58
  3. click click click driveing me mad!
    By bangty 1 in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 20:10
  4. Well of course I'm going to click it......
    By spoons in forum The 'Off Topic' room
    Last Post: 12th July 2008, 22:10
  5. WOW...WOW just click and see yourself
    By Saimir in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2006, 08:39
reset deadlock vectra
