Results 1 to 10 of 17
Thread: Urgent help needed...where can I get one of these???
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Default Urgent help needed...where can I get one of these???
    As the title says
    I seem to have misplaced one of the below bolts
    Its the one from my EGR that holds the bracket for the engine cover to pop on to
    Its a 10mm bolt with thread at both ends but not in the middle and has a hex head already on at one end about 10mm in from the top
    Any help would be appreciated!!!
    I've tried ebay and B&Q so far
    The bolt on the left of the first pic
    Full Member Big Sig's Avatar
    Looks like a bit of studding with a nut on it to me
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    6mm by the looks of it
    Jul 2010
    its 10mm, the bigger nut is 13mm
    Simmo 10mm nut is 6mm thread
    Jul 2010
    Sorry my bad
    Might just take a trip down to B&Q and see what they've got
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Hi simmo, think this is the part you're looking for (item 26) Part# - 93181664
    http://opeloem.com/opel/vectra_c_200...el_engine.html
    Hope that helps
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Get a bolt or a length of threaded bar with 6mm thread and saw it off to the length you need - put two nuts on the end and lock them together and screw it into the threaded hole - tighten it up - remove the two nuts and Bobs your Aunt Fanny!
    Engine : 1.9 CDTi
    Or buy the correct one from Vauxhall
    Jul 2010
    That's the one mate can't find it anywhere online though so I will have to order it from vx
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
