Thread: electro hydraulic power assisted steering warning light
    Regular Member dodus's Avatar
    Jun 2009
    edinburgh
    Default electro hydraulic power assisted steering warning light
    Hey me again today when i was driving this light came on only briefly,but i had been noticing that sometimes the steering got heavy and then back to normal,is there a quick fix for this like power steering fluid top up?
    Feb 2011
    Selby
    Whether there's a quick fix depends on what the fault is. It's certainly worthwhile checking the power steering fluid level though, although it's meant to be fairly maintenance free on the Vectra as it's a semi-sealed system. You must get the fluid from Vauxhall, it's not the common ATF type hydraulic fluid. However, it's not expensive so not to worry
    Jun 2009
    edinburgh
    heres a silly question where is the power fluid container under the bonnet? i am looking in manual but it dont say
    Quote Originally Posted by rich r View Post
    Nottinghamshire
    You don't say what engine you have. It's either on the bulkhead or in front of the offside front wheel. Follow the pipes from the steering rack to find it. The latter sort is easiest accessed by removing the front bumper. Top up the fluid as required.
    If you have the one in front of the wheel, while you are under there check if you have a fluid level sensor next to the filler cap (on a short wire which runs down to the EHPS ECU under the fluid bottle). These were fitted to early cars and are known to give false low fluid warnings and now have to be programmed out (or ignored) as the part is no longer available. You'd need to read the fault codes to find out if this - or whatever else it might be) is the issue first though, but hopefully it's a genuine low fluid warning.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by dodus View Post
    Have your alternator and battery checked - that's a classic sign of alternator failing - also check the plug - in connectors to the p/steering pump.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Jun 2009
    edinburgh
    hi its a 1.8 ls and now the power steering warning light has come on,where are these wires to the power steering pump?
    Jun 2009
    edinburgh
    its a 1.8 ls 2003
    Quote Originally Posted by James24 View Post
    If you have the one in front of the wheel, while you are under there check if you have a fluid level sensor next to the filler cap (on a short wire which runs down to the EHPS ECU under the fluid bottle). These were fitted to early cars and are known to give false low fluid and now have to be programmed out (or ignored) as the part is no longer available. You'd need to read the fault codes to find out if this - or whatever else it might be) is the issue first though, but hopefully it's a genuine low fluid warning.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Had your battery and alternator tested - also the large cable connector on your EHPS unit - check its clean and not loose
    Jun 2009
    edinburgh
    ok i found it but cant access it its behind the wheel,so do i need to take of the wing or the bumper?also its not stopped raining for a week so i cant work on it lol
    Quote Originally Posted by alcutler View Post
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power Steering Warning Light
    By MrDerv in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2014, 19:49
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. electro-hydraulic power-assisted steering light
    By davidsi in forum Engine & Drivetrain
    Last Post: 31st May 2011, 21:39
  5. Power Assisted Steering
    By S888 SRB in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2007, 21:12
electro hydraulic power assisted steering vectra
electro hydraulic power assisted steering fault
how to fix electro hydraulic power assisted steering
electro hydraulic power steering warning light
vauxhall vectra power steering warning light
electro hydraulic power sssisted warning
vectra power steering light
vectra c fault in lights and power steering clicking
fault in the electro hydraulic power assisted steering
vauxhall power assisted steering
vectra ELECTRO HYDRAULIC POWER ASSISTED STEERING light meaning
electro hydraulic power assisted steering warning sign
vauxhall vectra electro hydraulic power steering fault
2004 vauxhall signum hydraulic steering
vauxhall:vectra power assisted steering
vectra c power steering warning light
how do you fix the ELECTRO HYDRAULIC POWER ASSISTED STEERING The Vectra power steering
