Thread: wiper and washer problem
    May 2012
    Glasgow
    Default wiper and washer problem
    Hi guys i have a problem that happened when there was snow where the intermitted wipers and front washers stopped working and when the tempature went up it worked .. now it is mid 20's and and the issue has came back front washers dont work and also the intermitted wipers dont work wipers just come on constant and i have to park them manually 2 days on and still not working .........has anyone got any ideas?
    11 Post(s)
    Re: the washers
    Have you checked the filter in the bottom of the bottle?
    http://www.vectra-c.com/forum/showthread.php?107593
    In the how2 section there is also a guide for wipers that fail to park.
    http://www.vectra-c.com/forum/showthread.php?90019
    May 2012
    Glasgow
    Yeah the rear washer works and you can hear the pump but not when I try the front ones
    Feb 2011
    Selby
    No intermittent wipe, having to park manually, and no washers is the classic sign of a failed wiper motor on the Vectra C. There's an article on here somewhere about fixing it (it's just a poor electrical connection to the microswitch inside the unit). Alternatively you can pick up a complete unit cheap enough on eBay. An hour or so to replace it.
    May 2012
    Glasgow
    Is the washer pump and wiper motor from the same feed ?
    11 Post(s)
    Quote Originally Posted by rich r View Post
    No intermittent wipe, having to park manually, and no washers is the classic sign of a failed wiper motor on the Vectra C. There's an article on here somewhere about fixing it .
    I posted the link to the article earlier in this thread.
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Washer/Wiper problems
    By mycarvec in forum Vectra C / Signum Troubleshooting
    Last Post: 8th June 2010, 22:47
  3. Rear wiper and washer
    By TimK in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2010, 19:15
  4. Washer Problem AGAIN
    By craig-k in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 22:16
  5. washer/wiper operation advice
    By bygumlad in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2009, 18:09
