Results 1 to 10 of 16
Thread: egr valve
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default egr valve
    is it possible that the egr valve gets dirty, turns on the eml and then after driving it like that for a few days the valve gets more blocked and stops the car from being driven?
    the car was on the way to garage to replace egr valve under warranty but has broken down and is being recovered.
    i am hoping cleaning the egr valve will solve the issue?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Cleaning the egr valve will certainly help , but what fault codes were generated to make you think it was the egr apart from the garage telling you it is .
    You have watch out with stealers as its one of there favourite ploys to tell you something is faulty , then you end up forking out for a new component only to find a couple of days later that was not the problem at all .
    and still loving it
    Sep 2011
    Birmingham
    Trim : sri
    i didnt manage to do the pedal test tbh so its based on what the garage told me but as i have never cleaned the egr it could well be right.
    i guess the best thing to do is clean the egr valve, bolt it back on and see what if anything has changed.
    i will also try this pedal test i think
    Sep 2011
    Birmingham
    Trim : sri
    and the egr valve was to be replaced under warranty so i wasnt forking out for it anyway but i know what you mean.
    i am going to get a code reader, wont bother with the garage again
    Engine : 2.0DTi
    Mileage : 73350
    Jps just ask on the forum if there is someone near you with a tech2 or vaux com .
    Who is willing to read your codes at least then you will know what is required .
    and still loving it
    Sep 2011
    Birmingham
    Trim : sri
    not a bad idea actuall, i have ordered a code reader from amazon but that wont be here till next week.
    first job tho as its so easy and may wel fix the problem is to clean the egr valve i think.
    they also said there was a fault code for glow plugs showing but diesels will fire on 1 or 2 so they cant be that bad but will be repalced asap as i have no idea when they were last done anyway
    Sep 2011
    Birmingham
    Trim : sri
    update, the pedal test doesnt seem to work, the eml is just on constantly.
    took the egr off, it was disgusting, i was able to scrape chunks of soot out! gave it a good clean and put it back on with the original gaskets as i cant find anyone with new ones in stock yet.
    the car does now drive at least which is an improvement on earlier.
    a couple of questions, the eml is still on and that is keeping the car in limp home mode, can it be turned off without a code reader?
    also, why doesnt the pedal test work, any ideas? brake and accelerator pressed, ignition on, i just get eml on not flashing.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Have you tried just disconnecting the battery for 10 mins or so, should clear the fault from the ECU, but the EML will come back on if the fault is actually still there.
    Sep 2011
    Birmingham
    Trim : sri
    no i havent heard of that one, will try it tho, cheers
    just one lead off or both?
    Sep 2011
    Birmingham
    Trim : sri
    shouldnt affect the stereo either as its aftermarket now
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Troubleshooting
    Last Post: 6th July 2007, 00:43
