Results 1 to 10 of 11
Thread: Tail lights constantly on...
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Default Tail lights constantly on...
    Hi guys, bit of a strange one, the other night I noticed my tail lights where on even though the light switch was in the off position, I've been checking them since and it would seem as soon as I turn the ignition on the tail lights come on and stay on until ignition is off again.
    Not sure why this is happening? Only the tail lights are coming on, no font side lights etc... and I'm sure this didn't always happen (owned the vec for around 5 months now)
    I thought perhaps the alternator was overcharging the battery but its only around a year old according to paper work which came with the car and looks rather new still, and its covered less than 7k + the engine doesn't have to be running for the lights to come on. I will be testing it with a volt meter to make sure but until then anyone got any ideas?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    PRobaly activated the driving lights in the REC.
    Norfolk
    Mileage : 69'000
    Never thought of that Ken, I will plug the laptop in and double check I haven't turned it on by mistake!
    Norfolk
    Mileage : 69'000
    good call Ken! somehow the daytime running lights where set to 'version 2' what ever that means, certainly don't remember activating it, any how the lights are now off!
    Jan 2016
    I've got this problem too
    Sent from my SM-G900F using Tapatalk
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    you've set yours to daytime running lights version 2 as well?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jan 2016
    How do I turn it off ? Do I need special software
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    is this somethign that has just happened or has someone been playing with the car?
    try lifting the brake pedal manually, does this make a difference?
    have you tried disconnecting your battery for 5mins? (if the car is pre2005, make sure you have your radio code first!)
    Jan 2016
    The car was like this when I got it and the previous owner said it had always done it ..
    Jan 2016
    My car is a 2007 signum, is there a setting in op com I need to change ?
  1. Tail lights?
    By Matt_Bankier in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2011, 09:17
  2. My New Led Tail Lights
    By 06bba04 in forum Styling
    Last Post: 2nd May 2011, 14:34
  3. Tail lights
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 20:26
