Results 1 to 10 of 16
Thread: Expansion tank trouble
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Expansion tank trouble
    When my 1.8 vvt gets to running temparature the expansion bottle fills rite to the top and water spill out of the two holes at the top! Fans slowly kick in and water goes down for 30 seconds and then rises again! There isnt too much water in as when its cold the water sits below the max fill line in the centre. Anybody have any ideas? Cheers
    Barrow In Furness, Cumbria
    Sounds like a possible head gasket failure... How many miles has it done?
    Sep 2010
    Leeds
    92k ive had head gasket test done and no gases are escaping
    May 2012
    NW UK
    Thermostat stuck closed? It's only a guess, I'm a useless mechanic!
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    fans not kicking in to cool car down as said thermostat air lock in cooling system
    replied to your pm tonight as i havent been able to get on the forum lol
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Failed water pump. Can you see water returning to the header from the small pipe, this will happen from cold as its the bypass untill the thermostat opens.
    Sep 2010
    Leeds
    It just fills to the very top and goes everywhere if the lids off or if lids on just bubbles where the little pipe at the top is and comes out of back tube! Ive tried parking on a hill and revving with cap off to get rid of any air locks, but little help. Even at hot running temp my pipes are hot but not hard if this helps??
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    weired one eother stat or water pump mate wich needs checking
    Sep 2010
    Leeds
    Cam belt just been done on it, so maybe a water pump failure, what are the symptoms of this and worse scenario as im doing a 300 mile round trip next week!?
    May 2012
    NW UK
    Well... the worst case scenario is that it overheats and the engine seizes! Hopefully it won't come to that
    Does the temperature gauge look OK or is it pretty high?
  1. expansion tank
    By Swedge in forum Engine & Drivetrain
    Last Post: 1st August 2012, 18:21
  2. Where to get a new expansion tank
    By Morephun in forum Engine & Drivetrain
    Last Post: 19th December 2010, 19:53
  3. expansion tank
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2010, 21:25
  4. Expansion tank cap!
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 17:51
  5. expansion tank
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2009, 17:41
