Results 1 to 10 of 20
Thread: U480 Code Reader says 'Linking Error'
    May 2012
    Devon
    Default U480 Code Reader says 'Linking Error'
    Hi,
    I have just got a U480 Code Reader and tried it on my '05 2.0dti Vectra and it goes through the process to find the protocol but continually comes up with 'Linking Error'
    I have seen some discussion that these readers do not work with certain vehicles, something to do with steering wheel controls.
    My car's steering wheel has 2 buttons & a scroll wheel on the left hand side and also 2 buttons & a scroll whell on the right hand side.
    It is an '05 car, a pre-facelift, so according to the seller I got the reader from, it should work, they states;
    all post 2001 petrol & all post 2004 diesel.
    Has anyone else got this reader and used it on the same model and age car as mine?
    Regards..,
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I've got the same code reader as you. Mine works on my 51 plate petrol Astra but not on my preface 2.2 dti Vectra. I don't think you will get it to work. I don't think the dti's ecu is completely OBD2 compliant regardless of year. If you had a cdti you probably wouldn't have had any problems. Your steering wheel controls just give you a clue as to whether the car is full canbus or half canbus.
    Feb 2012
    Oldham
    Have you tried it both with the ignition on and also off?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I have the same code reader. It worked rarely on my old DTi (2.2) and mostly gave a linking error. Numerous re-tries and it did link up.
    It works every time on my CDTi though.
    I have read somewhere that the DTi's don't like some of the cheap code readers.
    West
    I agree with Tony, i also struggled to find a code reader for my old dti
    May 2012
    Devon
    So I am guessing that none of the code readers on fleabay are really suitable for my DTi?
    Mar 2012
    Exeter
    Hi,
    I bought U480 and it didn t work for my 2004 2.2dti as well.
    Some of scanner adverts on ebay say suitable for vectra A B C but when I look carefully there is not vectra c between 2002-2005 they start from 2006. so it will be difficult to find one. If someone found, it would be nice to share with us. I have 2 scanners which don t read now and don t want to buy third which won t work.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    my u480 arrived this am, doesnt work with my 07 cdti tho so i am still stuck with same problem, i may try it a few more times tonight but tried 4 times so far and just says linking error.
    not sure what to do now
    May 2012
    Devon
    Quote Originally Posted by J P S View Post
    Is yours saying 'Linking Error', or just not working altogether?
    I contacted the ebay seller that I got mine from and this is the response:
    Hi friend
    We are sorry to hear that it shows link error,it means that Car ECU communication agreement does not support,you can test it on other car from your friends or family.
    It is no problem if you want to retrun for full refund.
    We are looking forward to your respond.
    Regards
    Sincerely, Amy/goodgood323
    I am not entirely happy but for just £16.94 that I paid for it, it is not worth arguing about, I'll just keep it for the future.
    I do also own an '04 Laguna, which I will try out the U480 on to see if it works on this car.
    Sep 2011
    Birmingham
    Trim : sri
    mine says linking error after flashin up the other stuff that the book says it should.
    i will try it on other cars before looking to return it tbh bu hopefully i can get it to work on mine
  1. u480 code reader not working on cdti150
    By J P S in forum Vectra C / Signum Troubleshooting
    Last Post: 28th May 2012, 14:57
  2. u480 linking error
    By pol mike in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2012, 22:03
  3. u480 code reader
    Last Post: 23rd July 2011, 20:03
  4. For Sale: U480 Code Reader
    By Jonsey in forum Parts for sale
    Last Post: 11th June 2011, 22:08
  5. U480 Code reader = Gutted
    By Jonsey in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2011, 13:37
u480 code reader link error
u480 linking error fix
u480 linking error
u480 scanner linking error
can obd2 u480 linking error
memoscan u480 linking error
obd ii scanner u480 linking error
Opel zafira a obd linking error
obd 2 scan u480 error
obdii reader comes up with linking error
Opel zafira obd2 linking error
u480 code reader
memo scanner u480 linking error
linkink errorhow tofix citroen
code error memo u480
memoscan u480 link error
obd2 scanner link error
linking error u281
u281 scanner linking error
u480 linking error fiesta mk6
car scanner linking error
why does my code reader say linking error when used on an astra
memovscanner u 480 linking error
vauxhall vectra 2.2 diesel code reader not working
is vectra c obd2 compliant
